Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 11-27-2004, 09:45 AM   #1
almera's Avatar
almera is on a distinguished road
Lightbulb Power Consumption For P4 MB?
As a newbie forgive me if this question asked before but I need feedback from actual configurations.
I have Opus 150W Power Supply. For some reasons I am looking to purchase P4 based MB and Celeron or P4 CPU. It's hard to find mini-ITX boards in Turkey. Since Opus 150W Power Supply has P4 connector, it means only for mini-ITX P4 boards or enough to power micro ATX mainboards (ie Intel 845 chipset with Celeron 2.4 CPU)?
Anyone has a configuration like this?
If yes any startup difficulties?
As I made some measurements for Power Consumption during startup I saw consumption increases at least 2 times than standby.
Also I asked to some MB manufacturer they told me that required power supply for mentioned MB and CPU is min 200W.
Also I checked this power simulator:
http://www.epiacenter.com/powersim/e...ulator_tc.html
Intel845@1.8GHz option is for mini-ITX board only?
According to pc power and cooling:
Component Requirement Line(s) Used
AGP Video Card 30 – 50W +3.3V
Average PCI Card 5 – 10W +5V
10/100 NIC 4W +3.3V
SCSI Controller PCI Card 20W +3.3V and +5V
Floppy Drive 5W +5V
CD-ROM 10 – 25W +5V and +12V
DVD-ROM 10 – 25W +5V and +12V
CD-RW 10 – 25W +5V and +12V
7200rpm IDE Hard Drive 5 – 20W +5V and +12V
10,000rpm SCSI Drive 10 – 40W +5V and +12V
Case/CPU Fans 3W (ea.) +12V
Motherboard (w/o CPU or RAM) 25 – 40W +3.3V and +5V
RAM 8W per 128MB +3.3V
Pentium III Processor 38W +5V
Pentium 4 Processor 70W +12V
AMD Athlon Processor 70W +12V
For overall power supply wattage, add the requirement for each device in your system, then multiply by 1.8. (The multiplier takes into account that today’s systems draw disproportionally on the +12V output. Furthermore, power supplies are more efficient and reliable when loaded to 30% - 70% of maximum capacity.)
I'm confused.....
almera is offline   Reply With Quote
Advertisement Sponsored links
Old 11-27-2004, 09:48 AM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Depends on the hardware you use. The Opus is enough to power your board and chip for sure.
I'm using a desktop power supply, 140watt. I'm powering 2 desktop hard drives, desktop cd-rom, PSone screen, P4 2.0, and USB to IDE.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 11-27-2004, 10:19 AM   #3
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
try this calculator. they are only guidelines but close is probably OK
http://www.jscustompcs.com/power_supply/
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 11-27-2004, 10:32 AM   #4
almera's Avatar
Thanks you gave me a hint
Of course depends on the hardware and depends on software you run. With 140W PSU do you have problems at startup or running software like Office applications?
Old 11-27-2004, 01:47 PM   #5
Tidder's Avatar
No probs at startup, no probs running my software, CDex (ripping soft), or even watching DivX movies and stuff. Burning CD's, no problem either. It's been running pretty good for quite a while. Oh, and I forgot to mention, I also have a Geforce4 MX440 8x AGP card in there too.
Edit: Also have USB wireless network doober. And sometimes USB keyboard.
Tidder
Try RevFE
Best Quote EVER!!
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
New product - PC Power switch with wired remote hd54321 General Hardware Discussion 5 03-08-2006 11:48 PM
Power consumption Jimbo1978 General Hardware Discussion 4 07-07-2004 11:00 AM
MicroATX power consumption zvi Power Supplies 11 01-20-2004 11:29 PM
Too much power consumption with 300w - Need help wallachee Power Supplies 7 12-31-2001 12:49 PM
