Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 12-28-2004, 12:48 PM   #1
Legrath's Avatar
Legrath is on a distinguished road
Unhappy Carputer wont power up once Amp is installed
Hi,
I've had my Carputer installed with a Opus 90w PSU (full spec in sig below) for about a week now, everything running fine, but with no sound as Amp was not yet installed.
So today I install the 1400watt Amp. I wire it into the 8 Gauge Power wire and Earth that I have already installed for the Carputer. Now the Amp powers up fine, but the Carputer will no longer Power up. No lights nothing. I disconnect the Amp and the Carputer works fine again !?
Both the Carputer and Amp are running of the same Power and Earth Cables. 8 gauge cable.
Im confused
Is the Power cable to weak for both the Amp and Carputer, is the Amp draining all the power ?
300zx TT Manual
- VoomPC Case, M1-atx PSU
- VIA EPIA MII-12000
- 60gb slimline, 512mb, DVD/CD
- 3G/GPRS PCMCIA Data Card
- USB GPS receiver
- USB WinTV FM
- 7" VGA Touch screen
- Pioneer Steering remote
- Creative Extigy USB Sound
Legrath is offline   Reply With Quote
Advertisement Sponsored links
Old 12-29-2004, 08:09 AM   #2
R@b
R@b is on a distinguished road
Buy another set of cables and a fuse and connect the carpc seperatly.
Your cables are probably too thin and can't power on both.
R@b is offline   Reply With Quote
Old 12-29-2004, 08:27 AM   #3
ea972271 is on a distinguished road
How are you splitting the power wire? Distrubution block? or are you just daisy chaining the components?
ea972271 is offline   Reply With Quote
Old 12-31-2004, 08:20 PM   #4
Zac
Zac is on a distinguished road
1400watts and a CarPC on an 8ga. wire? ......Run another 4ga line seperatly for the amp and you should be fine. "1400w 4 channel amp" eh? 350 watts x 4? No name brand listed either?
Zac is offline   Reply With Quote
Old 06-20-2005, 07:07 PM   #5
Qnzfinest is on a distinguished road
8ga wire is too weak to run something as power hungry as an amp and a computer. best bet would be to run fused 4ga wire from battery to trunk, install a fused 4ga-dual 8ga wire distribution block and run to each device respectively. Then take a 4ga ground wire and run to a ground distribution block and wire to the amp and puter. Most Ground Distribution blocks come with a 1 4ga to 4 8ga distribution. This should solve your problem. Also make sure that you main fuse on the 4ga wire is strong enough not to blow when u have the amp and the computer on
Qnzfinest is offline   Reply With Quote
Old 03-19-2007, 10:23 AM   #6
david69leonard's Avatar
david69leonard is an unknown quantity at this point
david69leonard is offline   Reply With Quote
Old 03-20-2007, 11:16 PM   #7
ajscomp372's Avatar
ajscomp372 is on a distinguished road
Another reason for having the thicker wires is voltage drop. The thinner the wires, the greater the drop in voltage on the wire. If the wires are too thin and/or too long, the voltage could drop enough to trip the low-battery settings of your amp and computer, or at least cause some sort of small-scale electronics havoc.
ajscomp372 is offline   Reply With Quote
car amp power supply fuctup Power Supplies 3 11-03-2004 02:52 PM
cant get power to amp Murphy3603 Car Audio 6 10-28-2004 03:43 AM
XBOX, Carputer, power Question! ELECTRIC GURUS HELP! EggrollXpress61 General Hardware Discussion 5 08-21-2004 12:15 AM
seperate amp for carputer schrodos General Hardware Discussion 2 11-12-2000 10:00 PM
Constant power cycling of carputer moossmp3 General Hardware Discussion 3 11-06-2000 07:41 PM
