Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 12-30-2004, 12:11 AM   #1
Running out of serial ports
Is there a way to increase the number of serial ports? I have the M10000 motherboard. I want to run my IR reciever, temp sensor, and OBD. To my knowledge, I dont think I can convert any of these to USB. What can I do to get around this problem?
Tred is offline   Reply With Quote
Old 12-30-2004, 12:24 AM   #2
Jesus Freak
antimatter's Avatar
Well you got out of three devices covered since the m10000 comes with 2 onboard serial ports, are you sure that you can't use a serial-->usb convertor for any of those. Another option is to use you 1 pci slot for a serial port card. You can get one with 4 serial ports
antimatter is offline   Reply With Quote
Old 12-30-2004, 12:59 AM   #3
Curiosity's Avatar
I have 3 or 4 of those USB converters already. They work great and are less than $10.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 12-30-2004, 01:01 AM   #4
ohh yeah, I forgot about the extra onboard serial.
PCI is out of picture, im using that for wifi.
I just remembered I have 2 Infrared ports on the motherboard. They are called Fast IrDa and Consumer IR(CIR). Does anyone know the difference? and how I could implement one of these ports to use with a serial IR receiver, which runs on Girder?
Old 12-30-2004, 01:03 AM   #5
what are hardware are you converting? OBD?
Old 12-30-2004, 09:00 AM   #6
Curiosity's Avatar
Creative media remote, radioman and something else. The OBD is on COM1 but works on a USB converter too. They work exactly like a regular COM port.
Old 01-02-2005, 01:55 AM   #7
Curiosity's Avatar
I lied! Don't get one that looks like this transparent blue one. The serial part works but the DTR/DSR/RTS/CTS/RING pins do nothing. Not all USB serial adapters are created equal?
Old 01-02-2005, 04:36 PM   #8
ok thanks. so which one should I get?
Old 01-02-2005, 05:28 PM   #9
Curiosity's Avatar
The funny thing is I bought the good one there, but I guess they found something cheaper to sell for the same price. It looked like this one before I cut all the black plastic and DB9 off.
Edit: Just ordered this along with some other toys. I prefer the size so I can chop it up, cut the serial cable off the other thing, and make it all one small USB device.
Old 01-02-2005, 06:17 PM   #10
aultl's Avatar
Why don't you buy one of these? Edgeport/4 USB. Here is one on ebay... http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW for cheap..
The last company I worked for uses these in all the convienent (sp?) stores, the POS systems run Win2K
Aultl
[====---] - 65% complete
Status: Configuring Software
VIA Epia 800mhz, 256Mb ram, 10Gb HD
Quote of the Month: "I see the problem, [The RAID controller] is trying to rebuild the array with good data from a failed drive." -- HP Support
aultl is offline   Reply With Quote
Old 01-06-2005, 01:20 AM   #11
hd54321's Avatar
IrDa is for data transfer (i.e. one of those cheapo USB->IrDa converters could do the same job)
Consumer IR is the same IR used in remote controls. I would think all you need to do is hookup an IR LED with maybe an inline transistor/resistor directly to this port.
Someone else may have better knowledge but you should find some info about onboard IR ports on motherboards. Google is your friend.
-HD
hd54321 is offline   Reply With Quote
Need three serial ports on VIA Epia - OK? nxt125 General Hardware Discussion 16 01-27-2006 03:24 PM
Epia M (900) and missing serial ports? slboytoy General Hardware Discussion 2 11-07-2004 06:48 PM
Bad Serial Ports on EPIA M9000 wi77iam General Hardware Discussion 6 05-06-2004 11:49 AM
Pinout needed for serial ports? Sleeka General Hardware Discussion 4 11-09-2002 03:17 PM
serial ports and laptops blkdragon6 Laptops, Tablets, UPMCs, etc. 2 11-09-2000 10:14 PM
