Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 01-13-2005, 11:25 AM   #1
phatchink is on a distinguished road
What AMP fuse to use?
I'm in the final stages of buildign the carputer, I have one question.
So i'm connect the battery directly to the inverter then to the ocmputer, inorder to protect my circuit i'll have to put a fuse in between the inverter and battery???
if the above is true, then how do i know what amperage to use? Someone provide me with a formula?
phatchink is offline   Reply With Quote
Old 01-13-2005, 11:55 AM   #2
DallasCamaro is on a distinguished road
Well, Hopefully the inverter is fused itself, see if it has a fuse in it. If it does, it's still a good idea to put one right by the battery post, to shutoff that whole wire in case it were to short to ground. In that case, just use the same amperage fuse that the inverter already has in it. If it doesn't, then see if the inverter has a rating on it, look for Max. Input Wattage or Max Input Amperage. If no input levels are given, then there should at least be an output wattage on the inverter (i.e. 200 watt inverter). I would add 10% to compensate for the power being consumed in the inverter (turned into heat -- this would give us 220 watts in my example) Now that you have a gross input wattage, simply divide by 12 to find amperage. So for a 200 watt inverter, you should assume that input current will be just under 20A. Thus, a 20 amp fuse should suffice. I would personally use a 25A fuse, it will leave a little room on the circuit if you tap something in later on, but still will protect in case of a short. By the way, remember that you will have about 20 amps running through this wire, be sure to use a proper size wire for the job (at least 8 gauge, and in any run over 6 or 8 feet i would use 4 gauge)
DallasCamaro is offline   Reply With Quote
Old 01-13-2005, 12:10 PM   #3
Stank Cheese
n8scstm's Avatar
n8scstm is on a distinguished road
My 1500 watt inverter recomends a circuit braker rather than a fuse. You may want to consider that. Make sure you compensate for surge power. For example, my inverter is 1500 watts but the surge is 3000 watts. There is a %10 power loss also. So It's possible for mine to draw 3,300 watts which converts to 275 amps. So I would use a 300 amp fuse or circuit breaker. I used the cheap one but should have gotten the water proof one.
Fuse holder
Fuses
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
n8scstm is offline   Reply With Quote
Old 01-15-2005, 12:09 AM   #4
thanks for the excellent advice guys!
so what if i use a resister with a value too high, say i put a 30 amp fuse in instead of a 20 amp fuse? what' would happen then?
I'm guessing there'll be less current passing through the wire?
and fuses comes in a whole variety of shapes and sizes, are there any difference between them?
Old 01-15-2005, 12:13 AM   #5
30 amp fuse instead of a 20 will make no difference in the circuit....the fuses have no noticable resistance. You are only trying to use as small a fuse as possible, so that is something goes wrong <short circuit>, the fuse will blow before wires melt or something catches fire. If the entire circuit is run with good wire, there's nothing wrong with a 30 or even 50 or 70 amp fuse. As long as all the wires can support that amperage without catching fire. A 30 amp fuse will be fine for your application, just remember the 8 gauge wire, and a good matching ground wire.
Old 01-15-2005, 12:24 AM   #6
fantomas's Avatar
fantomas is on a distinguished road
how many watts is your inverter? do essentially what dallas said to find out the amperage that you're pulling, and use this chart:
http://www.crutchfield.com/S-uSUSbPv...ble_gauge.html
to figure out what size wire to use.
put the fuse within 18" of the battery. the closer, the better.
by resister do you mean fuse? if you use a larger fuse, more amperage will be able to pass through the wire before it pops. so, for the purpose of this discussion, you put a 150 amp fuse on a 10 foot piece of 12 gauge wire. the 12 gauge wire will only be able to handle up to (using the above chart) 20 amps. if there is a short in the wire, as in it touches the car chassis without mcuh resistance, the wire will heat up to a point where the plastic will start to melt, and eventually start a fire. if you had a 20 amp fuse on there, it probably would have popped within 5 seconds, thus saving your life and preventing a car fire.
point is, use a big enough fuse for the inverter, but dont use a fuse thats too big for the wire. if the inverter needs a larger fuse than the wire can handle, use a thicker gauge wire.
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
Old 01-16-2005, 01:52 AM   #7
Stank Cheese
n8scstm's Avatar
Nice chart but damn, they never go up high enough for my 3000 watt inverter and amps that im running on the same line. I hope my 1/0 wire is good enough. Im only running it about 5 feet. Anyone know of another chart?
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 01-16-2005, 02:42 AM   #8
fantomas's Avatar
3000 watts, max, right? you realise the usual house circuit is only 15-20 amps....which is at most 2000 watts. this is why space heaters only go up to 1500 watts....
Old 01-16-2005, 11:11 AM   #9
DRWeside is on a distinguished road
How many alternators do you have in your truck? That inverter will suck up to 250 amps.
DRWeside is offline   Reply With Quote
Old 01-16-2005, 01:25 PM   #10
Sofa King Retarded
nsmoller's Avatar
nsmoller is on a distinguished road
by this, if i get a 400w inverter my fuse should be 40amps or less?
i'm running wire in a 4runner (SUV) to front seat area, approx 6' would do...
i could use 10g, but if i use 8 or less, is there a problem then?
i figure just incase i get a 750w inverter in the future
[4Runna]
next - wifi
nsmoller is offline   Reply With Quote
Old 01-16-2005, 01:33 PM   #11
Thanks fantomas. U laid out what I was trying to say. Big enough to handle the load, but small enough to protect the wiring. By the way....ALL wires attached to that circuit should technically be sized to handle the fuse. Thus, don't tap in a 20 gauge wire just to run to one little light bulb somewhere. If that lil wire shorts out, it could catch fire before the fuse blows. So, as Fantomas said, the fuse should be large enough to handle your loads, but small enough to protect every wire in the circuit. And, of course, as close to the battery terminal as possible.
Old 01-17-2005, 12:39 PM   #12
Stank Cheese
n8scstm's Avatar
You would have to put an additioal in-line fuse on the small bulb wire to protect it. I have a main fuse at the battery. That 1/0 wire goes to a fused distribution block with smaller fuses.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 01-17-2005, 12:41 PM   #13
Stank Cheese
n8scstm's Avatar
A 40 amp fuse would work fine. If you plan on using a 750 watt inverter in the future, I would use 6 gauge wire. There will be no problem in using a larger wire. It's just more $$$.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 01-17-2005, 12:45 PM   #14
Stank Cheese
n8scstm's Avatar
Yes that is 3000 surge, but for sizing wire and fuses you need to make sure you can accomidate that. Its 1500 watts normal. 20 amps * 120 volts is 2400 watts. But besides that, my inverter has 2 outlets.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Old 01-17-2005, 12:48 PM   #15
Stank Cheese
n8scstm's Avatar
I have one 130 amp alternator. I dont plan on using that many watts though. I'm only running the computer, stereo and some screens. But I got a good deal on the inverter and it's nice to know that if you ever need it, its there, at least until you kill your battery which would be pretty quick at 275 amps.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 03:41 AM
car battery Slurpee General Hardware Discussion 35 09-08-2007 06:30 PM
Car Audio People, Help me pick an amp / Jeep GC w/ Infinety System hevnsnt Car Audio 3 12-07-2004 07:34 PM
Wiring Distribution Fuse Box, cable length etc Pabs General Hardware Discussion 0 09-06-2004 05:59 PM
what fuse holder/fuse amp ratting to get? [H]Bugster Power Supplies 2 12-08-2003 02:53 PM
