Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 08-28-2008, 08:20 AM   #151
dmistry is an unknown quantity at this point
Mine is also under the driver side seat, made it much easier to wire it has been there for about 8 months and it have never been a problem.
dmistry is offline   Reply With Quote
Old 08-30-2008, 01:07 AM   #152
Crazyfool is an unknown quantity at this point
I just purchased a 04 Accord EX with dual climate controls. I have this radio. I see the pics on the first post, but no explanation is give how they installed it without tempering with the climate controls. Any links to explanations or videos will be greatly appreciated.
Crazyfool is offline   Reply With Quote
Old 08-30-2008, 07:13 AM   #153
blackcobra487 is an unknown quantity at this point
I believe the Metra dash kit includes adapters for dual climate control, although you loose the dual climate function. It basically downgrades it to standard climate control.
Edit: check this page for more info.
http://www.crutchfield.com/App/Produ...997864&tp=3486
Sorry, after I looked more it seems I was wrong. The Metra kit does not work for dual zone climate.
blackcobra487 is offline   Reply With Quote
Old 09-04-2008, 01:32 AM   #154
Acemaster24 is on a distinguished road
I've been looking for through the thread and I know I saw it somewhere but I can't seem to find it again. I'm looking for instructions on how to run wires up the middle of the car. Specifically how to remove the back seats and pull the wire through the carpet and remove the center console, etc... If anyone can point to the right post I would appreciate it. Thanks.
Car: 2007 Honda Accord Sedan SE
My Worklog
http://www.mp3car.com/vbulletin/work...da-accord.html
Acemaster24 is offline   Reply With Quote
Old 09-04-2008, 02:23 PM   #155
skuller is an unknown quantity at this point
to remove the backseat,
find 2 hook on either side of the seat, pull it and the seat will pop.
you should buy honda service manual, it tells you everything you want to know.
http://www.handa-accessories.com/accmaint06.html
$78
skuller is offline   Reply With Quote
Old 09-27-2008, 12:18 AM   #156
bphnn is an unknown quantity at this point
need help please !
Ive been researching this for awhile now and never seem to find an answer for it. I was always curious instead of buying the stereo kits for the 03 accord to put in a aftermarket radio, couldnt I just purchase the front faceplate of the unit with the navi, and put in my own aftermarket double din unit ?? Has anyone ever tried this or is it even possible. I like the look of the stock radio but really need to put in a double din and I dont want to put it in the cubby hole.
bphnn is offline   Reply With Quote
Old 09-29-2008, 02:37 PM   #157
john05srt4's Avatar
john05srt4 is an unknown quantity at this point
Nope cause the navi dash AC controls are different i am pretty sure.
My Accord CarPC
john05srt4 is offline   Reply With Quote
Old 09-29-2008, 04:25 PM   #158
Here's what I would do if I were you: http://www.mp3car.com/vbulletin/fabr...rd-7-mold.html
This way, you could buy the cheaper stock radio and hack that up. It'll give you the look you want.
03 Accord Sedan CarPC
Old 11-24-2008, 01:34 AM   #159
hi guys, I'm having some issues with my power supply. Where did you guys get the ignition signal from and how did you wire it? Pictures would be great. I'm having a problem when I turn off my car the m2-atx does a hard power off instead of shutting down. This is my second board and I tested it on the bench. So I think it's where I wired my ignition wire. Thanks for the help!
My Worklog
Old 11-24-2008, 01:41 AM   #160
I am using the cig. lighter for the ign.
did you wired the power to the ignition?
The ignition wires have nothing to do with your m2 doing hard shut off. Unless the m2 is drawing power from the ignition
dsatx in voompc 2 case <HERE>
Old 11-24-2008, 11:55 AM   #161
Sounds to me like you've got the positive and the ign wires backwards on the M2. Give that a double check.
Old 02-09-2009, 10:25 PM   #162
studio8 is an unknown quantity at this point
03 honda feedback problem
Ha all new to this forum site but no one else seem to be able to help me. I have been putting in car stereos forever now, but in my 2003 honda accord coupe i have a really bad feedback issue. I even went so far as to run my ground wire all the way up to the battery. Im running an alpine mrv 1001 to one 1500 watt type R, My head unit is an iva d300. but wondering if anyone had a problem like this or if someone can give a good spot to hook up the ground? thanks
studio8 is offline   Reply With Quote
2003 Honda Accord Ex V6 puter Google Show off your project 22 09-05-2008 12:41 AM
need tips for 2004 accord sedan install keghead General MP3Car Discussion 25 07-07-2006 05:48 PM
95 Honda Accord In-Dash Install Gewehrschuss Show off your project 6 01-24-2005 12:52 AM
Full install Honda accord aerodeck ColonelB24 Show off your project 14 09-08-2004 11:21 AM
GPS for composite screens...Copilot 2003 vs. Routis 2004 bankingdom GPS 5 05-12-2004 10:42 AM
