Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 03-12-2007, 08:26 PM   #91
Telos is on a distinguished road
I'm a little unsure as to where the best place is to pull the wire through the firewall. I read through the thread, but I don't see anywhere specific mentioned. Anyone care to provide detailed info on where this factory grommet is located?
Thanks.
Telos is offline   Reply With Quote
Old 03-13-2007, 09:37 AM   #92
john05srt4's Avatar
john05srt4 is an unknown quantity at this point
It is under the dash close to the door it is a large black piece of rubber with a big batch of tapped up wires going thru it.
If you have a automatic there is one beind the pedals under carpet you can use.
My Accord CarPC
john05srt4 is offline   Reply With Quote
Old 03-13-2007, 12:27 PM   #93
mwmcginn's Avatar
mwmcginn is an unknown quantity at this point
I used the one over the drivers footwell.
Mike M
2006 Accord VP Sedan
My worklog
http://www.mp3car.com/vbulletin/work...-dads-car.html
mwmcginn is offline   Reply With Quote
Old 03-14-2007, 09:26 AM   #94
98EXL's Avatar
98EXL is on a distinguished road
I used the one where one of the main harnesses comes through...even got a 4 gauge wire through there as well
Molded Screen:
[++++++----] 60%
DVD & Rest of audio:
[++++++----] 60%
2004 Accord Coupe, Satin Silver K24 5 Speed powa!
7" Lilliput Screen, non touch with lots of Bondo
NTB DVD player or put XBOX in car
My 04 Accord Picture Thread
98EXL is offline   Reply With Quote
Old 03-14-2007, 06:28 PM   #95
Tensai's Avatar
Tensai is an unknown quantity at this point
Red face
I've made some modifications to my door hinges that should allow it to function normally with the screen in place as shown below. However, the modifications are wide enough that, once I put it in, I'll never get it back out. Unless I can remove the panel immediately to the left of the screen. (See image below, I want to remove the one circled in red.)
Does anyone know how to remove this panel? I've fumbled around with it and can't seem to find anything more than a few screws which don't seem to loosen it much. If anyone has any idea, or even better if there are instructions on how to do it somewhere that would be awesome.
Thanks!
Tensai is offline   Reply With Quote
Old 03-17-2007, 12:39 PM   #96
Where does that come out on the inside? I found a bunch of wires going through the middle of the firewall to the right of where the radio is, but i can't figure out where it comes through on the inside.
Old 03-19-2007, 09:30 AM   #97
98EXL's Avatar
stick something in it, and look for it on the inside....at least that is what I did
Molded Screen:
[++++++----] 60%
[++++++----] 60%
Old 03-25-2007, 01:44 PM   #98
Thanks for the help, guys. I was able to find the one by the door and use that.
I'm on to start working on the screen installation. I'm trying to do the same thing that was done here: Carputer Installs . I have it cut out and the front bezel fits in there nicely, but I can't figure out how he got the cover on there. The sides of the cover (the round parts that attach to the sides of the compartment) cover the holes that he cut to put the bezel in. The only way I can think of how he got around it was to cut off the sides of the screen bezel, leaving only the top and bottom to bondo into the compartment.
Anyone done this?
EDIT: Tensai, it looks like you've done what I'm looking to do. Could you provide details on how you got the screen in there and still have the door operating properly? Thanks.
Old 03-28-2007, 12:40 AM   #99
Tensai's Avatar
Door not done yet.
I haven't exactly finished it all yet. But my end goal is the same as yours. What I originally planned to do, and still haven't given up on. Is modifying the hinges. When I reinstall a few things here next weekend I"ll try to snap a few pics to help explain. But here it goes...
Before cutting space into the box for the screen, I cut out the parts on either side that the door mounts to. That is, I cut a large square out of each side so that all of the mounting holes / clips / etc were still intact with each other. Once the screen was installed and fastened in place where I wanted it I used plexi-glass to re-mount the squares with the mounting assemblies to the box so that they sat on either side of the screen. Basically, the plex-glass is just a spacer between the mounting squares and the original box sides. This way I didn't have to modify the screen casing at all.
My next move was to cut the door hinges just above the circular parts. I then used more plexi-glass pieces as spacers to move the round parts out and make them wide enough to fit on the widened box.
Once I got them all set, the door re-attached to the box and everything worked swell. However, I quickly found that the modified box/door combo was too wide to fit back into its original spot. Or rather, I could get it to fit, but once in I'd never be able to get it back out again. That may be acceptable for some, but I would like to be able to get this car back to stock if need be.
So I'm trying to figure out how to take the gray panel shown in the picture above off. That will allow me to slide the box/door combo in and hopefully figure out a way to be able to remove them as well.
If you come up with any ideas of your own I'm always looking for someone smarter than me to give me answers.
Old 03-28-2007, 06:07 PM   #100
I actually just finished my setup tonight. I was able to get everything in there and working without having to increase the width of the compartment. I would take pictures, but my camera just died on me. I might take some with my cell phone later this week to show how I did it.
Old 03-29-2007, 03:40 PM   #101
Tensai's Avatar
If you can get some pictures that would be awesome. Since as you noted, the pics that kuo posted aren't all that helpful. Are you using a xenarc screen or lilliput?
I think the depth of the xenarc allows you to do some things that you can't with the lilliput.
Old 03-30-2007, 07:35 AM   #102
I'm using the xenarc screen. I'll see if I can get some pics this weekend.
Old 03-30-2007, 08:46 AM   #103
98EXL's Avatar
yes please, I am just curious
Molded Screen:
[++++++----] 60%
[++++++----] 60%
Old 03-30-2007, 11:04 AM   #104
mwmcginn's Avatar
Congrats Telos. Cant wait to see it.
Mike M
My worklog
Old 04-02-2007, 07:01 PM   #105
Here are some pics of the screen. Sorry about the quality, I took them with my cell phone.
Here is the side with the main mechanism on it. You can see I cut away a big chunk out of the side of the bezel. It's important to make sure the bezel does not twist when you bondo it in, because your screen may not fit very well. I noticed very little twist in my bezel after fabrication was done.
I didn't have to cut the bezel apart on the other side because there was no complex mechanism. I did cut away a fair amount of the round part on the door arm though, but it does not affect the operation of the door.
The other guy's setup didn't seem to have the back cut out, but I could not figure out how to get the screen in there without cutting it out. Even with it cut out I had a hard time angling the screen in and getting it to fit.
Here's the front of the screen. This is only the second fab job I've done like this, so I'm pretty happy with it.
If you have any questions about how I did something, just let me know and I'll try to answer them.
On another note, I'm going to be replacing my rear deck speakers in about a week. Anyone done this? Anything I need to know before I start? I've never replaced any car speakers before, so any advice would be great.
2003 Honda Accord Ex V6 puter Google Show off your project 22 09-05-2008 12:41 AM
need tips for 2004 accord sedan install keghead General MP3Car Discussion 25 07-07-2006 05:48 PM
95 Honda Accord In-Dash Install Gewehrschuss Show off your project 6 01-24-2005 12:52 AM
Full install Honda accord aerodeck ColonelB24 Show off your project 14 09-08-2004 11:21 AM
GPS for composite screens...Copilot 2003 vs. Routis 2004 bankingdom GPS 5 05-12-2004 10:42 AM
