boba-phett
Are you talking about the In-Dash CD changer, or the Auxiliary one? Because you would have to loose the Aux one to use one of the adapters that I think you're referring to.
This
is the one I use. Works great, but you would loose the Aux CD changer, if that's what you have. I'm guessing you don't though, since you also have XM. I would assume you have the In-Dash CD changer. But this would mean you would loose the XM feature. Although this might be able to work for you:
Xm adapter Haven't used it myself, but this would put XM through the computer, which can be controlled by a frontend. If you go this route, you will still have the CD changer and XM capability.
Bjois14
Check out this page. It's how I figured out how to remove mine.
http://www.cardomain.com/ride/561772/3
If you're trying to remove it to install one of these Aux adapters that Bob-phett is looking for, the plug is on the bottom of the radio. The radio won't need to be fully removed. But the cubby beneath would need to come out.
I have an 03 Accord with a completed Carpc project. Feel free to ask if there's anything else.
