The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 02-17-2005, 08:47 AM   #1
My Photos: (0)
Ground Wire Thickness Question
Okay, let's say I run a 4ga wire to a distrubition block and then from the block I have an 8ga wire to a 150w OPUS and an 8ga wire to an amp.
Should I ground the OPUS and amp using a 4ga or 8ga wire?
Thanks much.
wh0k is offline   Reply With Quote
Sponsored Links
Old 02-17-2005, 08:55 AM   #2
Vacheron's Avatar
Vehicle: 1995 FTO
My Photos: (0)
Thanks much.
You could happily use a 8ga wire to ground both devices. These runs will be comparitively short and so the (IxIxR) losses will be much smaller than your long distance run from the battery.
Ideally, you want to use the biggest cable possable for ground (especially if the runs are long) as the vast majority of interference and noise problems are ground loop related.
Project F.T.P.C.
Vacheron is offline   Reply With Quote
Old 02-17-2005, 08:56 AM   #3
My man uses Levitra.
Peoples's Avatar
Vehicle: '00 Honda Accord Coupe v6
My Photos: (0)
even if you were running 4 guage straight to the amp, you wouldnt ground the amp with a 4 guage wire. I would say to be safe ground the amp with an 8 guage, but the opus you should be able to get away with whatever guage is attatched to it....12 or whatever it is.
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 02-17-2005, 09:18 AM   #4
My Photos: (0)
Great--thank you guys.
I have one more basic (and probably stupid) question:
Most people recommend grounding to the "same point". Does this mean I should put ring ends on all grounds and then stack them up and use one bolt to connect to the frame? Or does it just mean the same "general area"?
Thanks again.
Old 02-17-2005, 09:51 AM   #5
blackbravo's Avatar
Vehicle: 99 Fiat Bravo 1.8 HLX
My Photos: (0)
Star Grounding. Yep good way to earth, all on on big bolt to bare metal.
blackbravo is offline   Reply With Quote
Old 02-20-2005, 01:37 AM   #6
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (77)
Thanks again.
same grounding point doesn't mean they have to all be on one big bolt, & they can be close to each other & fine. A good thing to consider to do it right is to use a junction block for your grounds,grounded with 4 gauge, 8 gauge feeds, same as power. costs more, but pretty pro.........
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
In search of an ignition wire witten Power Supplies 16 07-27-2006 01:29 AM
Finding good ground to prevent Ground Loop lookinco Power Supplies 27 11-04-2004 01:23 PM
Easy switch wiring question. tbird2340 General Hardware Discussion 4 09-06-2004 09:59 AM
Stupid question about OPUS wiring RS3RS Power Supplies 16 08-31-2004 01:33 PM
Opus 90W power supply wire, 8 ga wire? muldrick Power Supplies 12 08-27-2004 10:27 PM
Sponsored Links
Ad Management by RedTyger
