An Update:
After doing some more research I have decided to go the Mobile Athlon route.
I was going to buy a Mobile Athlon Xp 2500+ for around £60 until I remembered that I still have a 6 month old unused AthlonXp 2200+ (Thoroughbred B I think) CPU spare that I could use. I am going to use the "wire mod" to unlock the multipliers and then join the L5 bridges to convert the CPU into a Mobile Athlon-M 2200+!
Hopefully it works!
Now the thing that I am stuck on is the motherboard. The Biostar board that everyone says works fine with mobile chips is hard to find in the UK and seems abit dated:
http://www.biostar-usa.com/mbdetails...odel=m7ncg+400
I have never used a Biostar board so cannot comment on the quality either - usually just used Asus. Also I have read about the problems getting the board to turn on when used with an Opus unless the Opus has been specifically modified. I don't think mine will have been modified.
What are the alternatives?
Asus A7N8X-VM?? Seen a members with this board in their signature. Does it work well and turn on using Opus?
ASUS A7S8X-MX?? Don't think video quality is as good.
Any others?
Does anyone know if these boards will do 800 x 848? Is the resolution THAT important when used with a Xenarc; I thought it was more important for Lilliputs?
Also seen these integrated PC Chips boards with onboard AthlonXP 1800+ CPU's - look like they may be good value - but the on-board graphics seem to be poor quality.
Some input please
