The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Search this Thread Display Modes
Old 03-21-2005, 04:13 PM   #1
My Photos: (0)
I'm a newbie with this month's dumbest question!
Okay, I picked up a couple of 12V/DC headrest LCD's for my rear passengers similar to the pic below (The power/video cable is what I am most interested in asking about here)
The question: My wiring harness that came with each LCD plugs into the small DIN looking 3" cable coming out of the back of the LCD. Once plugged in, I then have one yellow plug (video) and another black female plug (power) on the end which is supposed to go to the video source and power source. My question is , what kind of cable plugs into the female power source jack and could I then proceed to run this directly to say the fuse box?
Any links or pics would be beneficial ...thanks
Tekmazter is offline   Reply With Quote
Sponsored Links
Old 03-21-2005, 04:55 PM   #2
Vehicle: Nissan 240SX
My Photos: (0)
it may just be a female rca plug on the power cord.
Can the yellow plug fit into the black plug??
My first carPC!
MP3/CD player
Celeron 633MHz - 10GB Seagate - 64MB PC100 - Win XP
Soon to actually find its way into the car!
hannibal is offline   Reply With Quote
Old 03-21-2005, 05:08 PM   #3
Raw Wave
EsKALad's Avatar
Vehicle: 1999 Cadillac Escalade
My Photos: (0)
lets see a picture of the female power plug!
EsKALad is offline   Reply With Quote
Old 03-21-2005, 06:07 PM   #4
My Photos: (0)
Okay, I ran out to the local electrical shop with cable in hand and found that this would be called an 'M-Plug'. Anyway, they had a plug like this:
attached to a cigarette lighter adapter which could work in this case. However, I'm looking to run this directly to the battery, a distribution block or to the fuse box. I think you get the idea. Anyway, I am thinking about cutting off the adapter but I am not sure which wire would be the positive and which one would be the negative. Basically the female jack is a round connector with a single pin in the middle. It looks similar to say a coax cable in form.
Old 03-21-2005, 06:49 PM   #5
HostileJava's Avatar
Vehicle: 1989 Honda Accord SE-i Coupe
My Photos: (0)
Whatever lead on the wire is going to the outside of the connector is usually neg and the center is usually pos.
Visit my website at:
http://www.hostilejava.com
http://hostilejava.com/gerbil5.jpg
HostileJava is offline   Reply With Quote
Old 03-21-2005, 07:42 PM   #6
My Photos: (0)
Hey HostileJava,
Thank you for that reply. Is there anything I need to worry about running it directly to the battery or via a power wire? The LCD is 12v/DC so I know I'm ok there, but someone mentioned something about needing to get the polarity before doing this, but I was under the impression that determining which wire is positive and which one is negative would be the same thing. Am I right in assuming this or am I misunderstanding polarity? Been a looooong time since I've done anything electrical.
Old 03-22-2005, 09:27 AM   #7
my nizzle
shizzle's Avatar
Vehicle: 98' Honda Accord V6
My Photos: (0)
I am assuming you are building a carputer? In this case you would need something to handle the amperage; those wouldnt last more than a few seconds, either way. You would run a single power line to the battery. If it is going to handle all you power needs, 8 guage wire is a minimum... 4 is what I hear most people using now. I used 8 back in the day for a 300 watt audio system and it was fine, with a 20A fuse. It didnt last but ten minutes with a 15A fuse. I went through three 15A fuses. Im still a n00b, dont be discouraged.
shizzle is offline   Reply With Quote
Old 03-22-2005, 09:29 AM   #8
my nizzle
shizzle's Avatar
My Photos: (0)
Old 03-23-2005, 11:51 AM   #9
My Photos: (0)
It's a monitor, not a 300W amp. I'm sure it will work fine on pretty narrow wire.
Just make sure not to install it to a circuit that will not be on when the car is off, or you'll drain your battery.
der_soldat is offline   Reply With Quote
Old 03-27-2005, 11:26 PM   #10
my nizzle
shizzle's Avatar
My Photos: (0)
I was just covering bases... if the "video source" needs power too, might as well run his own fused circuit.
I assume you mean TO NOT install it to a circuit that WILL be on when the car is off...
But yea, if you just need to power them little lcds, no prob.
a carputer is a little trickier.
Carputer status: [-*---------]
Im thinking laptop...
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Newbie question jaydm General Hardware Discussion 25 10-21-2006 10:07 AM
Complete Newbie Question. DomesticImport Newbie 15 07-07-2005 06:24 PM
The Newbie with another power question nixneon Newbie 1 03-21-2005 11:05 AM
Yet Another newbie question :) outdidya Newbie 4 07-12-2004 02:03 PM
Your basic newbie question here. tlbuckingham General Hardware Discussion 7 09-16-2002 01:42 AM
Sponsored Links
Ad Management by RedTyger
