Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 03-23-2005, 08:01 PM   #1
doogie_h is on a distinguished road
CArputer install and need info
I have a Sony VAIO desktop with a 1.6 GHZ Celeron. I am going to do a carputer install within the next couple of months and am researching what power supply to use. Some mother boards are called ITX and some are called ATX and I don't know what to do as far as power supply is concerned. Please help...
My idea for the install is this: tell me if it will work
-Lilliput 7in touchscreen
-Vaio desktop
-wireless keyboard/mouse
-GPS? need info
-bluetooth? need info
-4 channel amp to power speakers/remove stockhead unit
doogie_h is offline   Reply With Quote
Old 03-23-2005, 10:28 PM   #2
Sofa King Retarded
nsmoller's Avatar
nsmoller is on a distinguished road
you should do more research...
there are calculators on the site that will figure out how much wattage your pc will use
the current dc/dc power supply max is like 150 watts i think, so if you go above that you might want to get a regular powersupply for whatever you need and an inverter (its cheaper)
[4Runna]
next - wifi
nsmoller is offline   Reply With Quote
Old 03-24-2005, 12:36 PM   #3
themolt is on a distinguished road
If you want a cheap option that will do the job then your current setup plus a inverter will be the best.
I plan on a psu that uses a startup/shutdown controller (M1-ATX). More $, but better for the carputer.
Here are some calculators
Power Usage Calculators:
The CarPC Store
My MP3Car
JS Custom PCS
Mini-Box
themolt is offline   Reply With Quote
Old 03-24-2005, 02:20 PM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Look at the label on the back of the computer you intend to use. It will tell what the maximum wattage rating is. If it is 150 watts or less, you can go with a DC-DC solution. Otherwise, you can get an inverter that matches the rating. For good measure, get one with a healthy margin above that (i.e. get a 300 watt inverter for a 200 watt computer).
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Need help with this setup...Mainly Power Audamn Newbie 0 12-02-2003 05:09 PM
Need help Installing a 15in Flat panel monitor midtownhog Newbie 5 10-31-2003 08:37 PM
Need some help with sending audio to stock amp orangewhip General Hardware Discussion 12 09-04-2003 02:21 PM
Need help with prepping dos for install jwnumber55 Software & Software Development 1 02-14-2002 09:12 PM
Anyone doing a new install? Need this? az1324 Classified Archive 0 06-13-2001 08:34 PM
