Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 03-31-2005, 03:53 PM   #1
CavityCr33p's Avatar
CavityCr33p
Grounding things
What all should be grounded and where to is my question. I've read numerous posts saying ground everything to one point on the car chassis, and then I have read that you need to ground the inverter (neg cable) to the neg battery terminal.
From what I understand is that the
PC case
PC power supply
AMP
Inverter
All need to be grounded, any suggestions on this?
2000 Sunfire build 100%, or is it ever really 100%?
CavityCr33p is offline   Reply With Quote
Old 03-31-2005, 03:59 PM   #2
ddn
ddn is on a distinguished road
Everything should be grounded to a solid ground, it doesn't matter where if its a good ground. Grounding the inverter to the battery terminal is redundant, it doesn't hurt to do it there, but it doesn't matter.
I would also give your display a good ground, as well as anything else powered for that matter. When I first cobbled everything into my truck to test some things out, I realized my entire system (PC, display, power) was grounded through the cable going to my headunit AUX-in. Don't even ask how this came about...can you imagine the ground loop I was getting? It sounded like a turbo.
ddn is offline   Reply With Quote
Old 03-31-2005, 04:47 PM   #3
CavityCr33p
How would you recommened grounding the display?
Old 03-31-2005, 05:02 PM   #4
rubicon's Avatar
rubicon is on a distinguished road
To follow-up on ddn: grounding isn't critical, really, as long as (as (s)he said) you have a solid connection. Whats recommened is to keep grounding cables as short as possible - tie to a point on the chassis right next to whatever you're trying to ground. Don't run wire all over the place, in an effort to come up with a "grounding block" or some such like. You'll end up with a ground loop condition similar to what ddn mentioned.
As for your display, you should be able to just ground it, again, to the vehicle's chassis, once you've identified what cable(s) are to be grounded.
Oh, and CavityCr33p, following up on your initial post: all things that are DC-powered need to be grounded in some way, shape, or form. AC is a little different, but not much.
rubicon is offline   Reply With Quote
Old 03-31-2005, 05:41 PM   #5
Mad Ad's Avatar
Mad Ad is on a distinguished road
Indeed- ground to anything thats metal that is attatched to the body or chassis of the car.... if in doubt, test it with a multimeter in resistance mode (or a continuity tester)
dont pay attention to the Hi-Fi nuts that insist that the only good ground is using these grounding kits that run extra ground wires back to the battery, its one of the more insane wastes of money ive seen for a car.
Mad Ad is offline   Reply With Quote
Old 03-31-2005, 06:46 PM   #6
sansoo24 is on a distinguished road
Although if you have lots of wires that need to be ground in the same area a Distribution block isnt a bad way to go. Like mutltiple amps for example. I have four amps using 2 gauge power wire. So i got a 4x1 block. 0/1 gauge in and 4 2 gauge outs. It wasnt necessary but it did help clean things up and made taking the amps out for any reason a real breeze. And one thing you will learn about wiring. The cleaner and more oganized it can be the better off you are. Trust me. I once wasnt this way and have crossed many power and grounds together. Makes a cool spark but not good on anything.
sansoo24 is offline   Reply With Quote
Old 04-05-2005, 10:25 AM   #7
CavityCr33p
Awesome, thanks for the heads up! I hope this might help some other people with this bump!
Old 04-05-2005, 10:49 AM   #8
CavityCr33p
Quote: Originally Posted by joshthepilot
Kids and to their parents room cause their room is just too much fun to be grounded to.
Being a parent of two young children, I completely agree. I still remember being grounded to my room, I was like "No!!!! Don't ground me to my room!, well, Ok...if you have to...."
Sit back and played Mario Bros for hours on end.
Old 04-07-2005, 11:53 PM   #9
imaxorz is on a distinguished road
So anything thats DC have the plus going to plus, and the minus going to something metal close by?
imaxorz is offline   Reply With Quote
Old 04-08-2005, 04:00 AM   #10
Chase_UK is on a distinguished road
Adding to this, if the mobo is in a non-metallic case, should it be grounded directly (via a wire) to the PSU and HD?
Chase_UK is offline   Reply With Quote
Old 04-08-2005, 04:08 AM   #11
lastberserker's Avatar
lastberserker is on a distinguished road
Question
Same question: I'm assembling my stuff in a home-brewed non-metallic case.
Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
lastberserker is offline   Reply With Quote
Old 04-08-2005, 07:18 AM   #12
Pyrotek's Avatar
Pyrotek is on a distinguished road
I built a small wood/plexi case for my mobo and ran into the ground issue. What solved it for me was grounding the mobo, hdd, and psu to my ground block. I used some 12awg that I had extra from the install, prob overkill but eh.
M7NCG w/ mobile 2400+ | 512mb DDR400
3.5" HDD | Slim DVD/CD-RW
Linksys USB Wifi | Belkin USB BlueTooth
Opus 150w | Xenarc 7"
RoadRunner - Thanks Guino!
Pyrotek is offline   Reply With Quote
Old 04-08-2005, 07:36 AM   #13
yonu is on a distinguished road
ok question what is the best way to go about grounding the psu and modo just connecting a wire to it or what?
yonu is offline   Reply With Quote
Old 04-08-2005, 09:24 AM   #14
-zip-'s Avatar
-zip- is on a distinguished road
I want to know this too, is this what you guys call ground? the negative (usually black) wire pluged into the device?
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 04-09-2005, 12:48 PM   #15
-zip-'s Avatar
any answer on the ground being the negative or do you run a seprate wire for ground would be appreciated
Carputer
Sound Stage
Wild Things PSone LCD to PC godzi11a LCD/Display 17 11-22-2005 08:13 PM
Grounding Help mazda3uzr General Hardware Discussion 4 12-19-2004 05:12 AM
Rage against some stupid things kraft Off Topic 19 11-07-2004 05:29 PM
Grounding concern (not normal grounding issue) supralightning Power Supplies 2 03-22-2004 01:02 AM
Control things and display status of things All4Norway General Hardware Discussion 10 07-18-2002 02:32 PM
