Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 04-06-2005, 06:39 PM   #1
Wiring or converting rca connector screen to vga? Possible??
I have a screen with the normal video out connector (rca type) is there anyway of converting to a vga connector?
Would the quality be better? Than if i ran this with an rca to s-video cable?
As i would want to use as a dvd, winamp and maybe gps screen?
PLEASE HELP NOOB!!
philb is offline   Reply With Quote
Old 04-06-2005, 06:53 PM   #2
The screen
Old 04-06-2005, 06:58 PM   #3
Raw Wave
TruckinMP3's Avatar
hacing details on the screen will help: who makes it, what model is it... link to specs.
TruckinMP3
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 04-06-2005, 07:03 PM   #4
Its a pioneer screen, but was from factory so dont now which model!
Is it possible to split the wire in a vga connection? OR would s-vide be better?
Will quality be shocking? Screen is £70, so $125
Old 04-06-2005, 07:04 PM   #5
I see dead kittens
Quattro's Avatar
why are you double posting the same question?
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 04-06-2005, 07:14 PM   #6
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Use the S-VGA output. Change it to RCA and plug it into the monitor. VGA is not compatible with the RCA video (NTSC) signal.
Before you decide to use this as your main car computer interface, hook it up to a computer with an SVGA or RCA output and see if you like it. Expect it to be fuzzy and difficult to read the smaller text (anything under about 16 point).
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 04-06-2005, 07:39 PM   #7
Thanks, would it really be that fuzzy being only 6.5" wide?
Will it be alrite for winamp, dvd etc, just not gps?
Old 04-06-2005, 07:41 PM   #8
I see dead kittens
Quattro's Avatar
You should be fine with dvd, you may have some problems with reading the file names in winamp. Same problem with reading street names with gps.
Installed
Old 04-06-2005, 07:48 PM   #9
Any way of improving it?
Would it be any better if it was just straight s-video and no rca to s-video?
Old 04-06-2005, 07:51 PM   #10
I see dead kittens
Quattro's Avatar
I don't know how much clearer the text would be with just s-video, I wouldn't think it would be much of an improvement. If you really want to be able to read text I would suggest you buy a lcd with vga and sell your current lcd on ebay.
Installed
Old 04-06-2005, 07:54 PM   #11
I havent bought it yet!!
So how are you able to see stuff on the all in one units?
There arent vga connectiosn, there all rca? And what about when people have sat nav installed with no pc?
It was like £70, thats y i was interested, do u know of anything better for about the same price?
Old 04-06-2005, 08:01 PM   #12
Anyone?
Old 04-06-2005, 08:11 PM   #13
neon_eddy's Avatar
for me s-video makes a lot of difference.. it reduces color bleed by keeping the RGB signals seperate..
I used s-video on my TV for a media center and it worked well.. RCA also works but it's fuzzy..
VGA is the way to go but s-video can do the job. just make sure it's an s-video source..
Shawn
I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
Check out my web company Minneapolis Web Designer - Himmelberger Design
neon_eddy is offline   Reply With Quote
Old 04-06-2005, 08:12 PM   #14
jusatry's Avatar
Quote: Originally Posted by philb
Anyone?
Heres the answer, you may not like it, but here it is:
The resolution on a computer is simply so much higher than RCA/S-video can support that there is an UNAVOIDABLE LOSS OF QUALITY from VGA to RCA. You can watch a DVD or maybe use something like MediaCar (now RoadRunner), but beyond that, it just doesnt work. On a smaller screen it will be even worse.
All in one units use their own proprietary interfaces or design the images with s-video units in mind.
That said, if you want to do it cheap and good, the best way to go is whats called a "scan converter". It will convert VGA to RCA - whereas those cables on ebay will make you kill yourself. They dont work unless you have a video card that supports TV out on the VGA channel. [SIDENOTE - SEARCH BEFORE YOU POST, I ASKED THIS SAME QUESTION LAST WEEK AND GOT THE ANSWER I AM GIVING YOU]
jusatry is offline   Reply With Quote
Old 04-06-2005, 10:07 PM   #15
Raw Wave
TruckinMP3's Avatar
Anyone?
You waited 7 minutes... VGA is better (costs more) save your pennies and but VGA Xenarc is well regarded.
TruckinMP3
Read the FAQ!
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 06:25 PM
VGA vs RCA, which to use sxt173 LCD/Display 5 03-28-2005 01:11 PM
Allbrite and controller work with RCA but not VGA alti LCD/Display 22 01-05-2005 12:47 PM
VGA vs RCA & Touchscreen vs other integsrtite LCD/Display 3 12-02-2004 06:07 PM
Different display using vga and rca out, how? crispvx General Hardware Discussion 1 04-30-2004 10:32 PM
