Couple Questions about my setup idea...
I have a couple design plans I am thinking about. I have a 95 Pathfinder with a big trunk, and more importantly, a side storage bay (about the size of a case). Cost is a factor in the initial setup, I want to try to get the basic working with old equipment I don't care about and then work up from there...Anyways, I have two desktop computer available to me:
1. PII 500 Mhz, 196 RAM.
2. Athlon XP 1.5 Mhz, 256 RAM.
Regardless of what computer I use I will have a 3.5 inch 80 GB (5400 rpm) hard drive. My first question is should I use the PII 500 for power issues? If I use it I could get everything to run on an opus PSU, otherwise I have to use an inverter. If I use the opus how should I power the LCD? Also, how much drain can a typical car battery take?
The regardless of the computer I was planning on mounting it in the back on the car and running the cabling to the front. Since I am on a low budget I was going to use the speaker out from the computer to a tape converter to my stereo. I was also planning on using a wireless keyboard/mouse setup (mounted to the dash) with a 7 inch touchscreen. Any comments/thoughts/things I am not considering...please let me know!
