05-20-2005, 08:50 AM
#1
OPUS Power Supply & 19 Volts
I'm going to be using a Xenarc MP-SC8 in my project, but it requires a 19V feed. Does anyone have any experience with this box, and the power supply? I can't find any information on it on the Xenarc webite. I ordered the DC to DC adapter from them, but I don't know if it has any of the functionality of the OPUS power supplies to monitor voltage and condition the line. I'm wondering if I can or need to put an Opus in front of the Xenarc DC to DC adapter, and if so whether it will still provide the same functionality. Ideas?
Reason: fat finger
05-20-2005, 08:51 AM
#2
MySQL Error
BIG HINT: CARNETIX
EDIT: please ignore the following comment as i didnt realise this is in the noob section
 for **** sake.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
05-20-2005, 08:56 AM
#3
MySQL Error
just to help even more... http://www.mp3car.com/store/product_...products_id=94
(as you will see it is cheaper than the Opus too)
05-20-2005, 08:59 AM
#4
Thanks for the "BIG HINT". I hadn't come across anything on Carnetix in the past few weeks.
BTW - No harm, no foul. I know some of my questions are very elementary at this point, but I'll eventually be able to contribute to the forums as I get farther into this project.
Reason: fat finger
05-20-2005, 09:06 AM
#5
MySQL Error
What is the spec on the xenarc Pc you are getting?
The dc-dc you ordered from Xenarc is probably like a laptop dc-dc so it will have no SDC stuff or as good low input performance (ie for cranking). If it is a laptop dc-dc then the 140W carnetix should be fine.
05-20-2005, 09:17 AM
#6
Pentium 4 Based, Small Footprint: 5.82"x10"x2.79"; Built-in Audio & Video, 6-Channel Surround sound, 10/100base-T Ethernet, 3-USB 2.0, 1 Fire-Wire, 1 SPDIF, 1 Mic-in, 1 Headphone out, 2 PS2, 1 Serial. 19V DC power input.
Dimension (in): 5.82(W) x 10(D) x 2.79(H)
Operating Temperature: 32°F ~ 122°F
Weight: 3.3 lbs (barebone)
Intel 865GV / ICH 5 Chipset
FSB support up to 800Mhz
Full support of Intel Hyper Threading Technology
Dual Channel DDR support
Processor: Pentium 4 (2.8Ghz)
Memory: 1GB
Video: Fully AGP v2.0 compliant, high performance
256-Bit 3D/128-Bit 2D graphic engine, dual video overlay
windows for Mirror Mode display
Audio: Software AC 97 Audio CODEC
Storage: One 2.5 inch Slim Hard Disk
(Support ATA-33/66/100. MPSC8P only supports 2.5” HDD)
Power input: 19V DC
Chassis: Ultra light extruded Aluminum
Xenarc TSV-700 touchscreen
I opted for this setup due to the PCMCIA slot. I wanted to be able to use my Verizon wireless card for Internet access w/o being near a hot spot. I can't find any information about the Xenarc 12VDC to 19VDC power supply on their site.
05-20-2005, 12:14 PM
#7
This is what I'm planning. If anyone sees potential problems, or has any suggestions, or comments,.......
Please let me know.
05-20-2005, 12:27 PM
#8
MySQL Error
looks ok. i think.
did you see the thread on the 5V addon for the carnetix? it will provide a third output at 5V (so you can set the secondary to 12V) and then you can power a USB hub/GPS etc etc.
05-20-2005, 12:46 PM
#9
One point about your connection diagram. The Carnetix has a dlyon output which would be better for the amp remote switch on.....
Old setup Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
#10
MySQL Error
yeah good point. that should avoid the amp thud.
05-20-2005, 02:14 PM
#11
Thanks for the heads up on the remote switch for the amp.
06-05-2005, 10:30 PM
#12
2k5f150,
I have been looking at this same system. Do you know who the MB manufacturer is?
Memory: 1GB
Power input: 19V DC
06-05-2005, 10:40 PM
#13
*noob*
what program did you use to generate that wiring diagram? it looks really good
06-05-2005, 10:57 PM
#14
Admin. Don't bug or I'll byte.
Will you need the iSense line? That's specifically for the Mac Mini. Not sure if your Xenarc needs it.
06-06-2005, 05:29 AM
#15
I think you might need more then a 15 amp main fuse off the battery
your 12v off the power supply alone will pull close to that, nevermind how much that JL amp is pulling.
| Thread Tools |
| Display Modes |
Linear Mode
