Quote: Originally Posted by Rexx42
This has probably been asked before, but I would like to create a PC interface to monitor and control the systems in my old car. I have a source for all the sensors I need. I would like some infor on getting the sensor info into the PC and displaying it.
Ummmm....correct me if I'm wrong,as I've owned several gm's of this era,and I seem to remember them being carb'd and not an electronic control anywhere,not even an 02 sensor.The only thing I could see monitoring would be the spark,as they did have HEI ignitions.
You could convert to TBI with a Holley Projection system....then you'd have some control over the fuel map,and a few other variables.
Better yet,swap in an engine/trans combo from a later corvette or camaro,then you can use any standard gm obdII setup listed in the forums.
