Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 06-12-2005, 02:47 AM   #1
SniperXX's Avatar
Location: Southern California -- Diamond Bar/Walnut Area
SniperXX is on a distinguished road
Inverter Power Question
Ok well I will be powering my carputer with a inverter I already have. I have tested it and it works fine with my setup. Now all I have left to do power wise is run power to the inverter in my trunk.
I have alot of 16awg (copper oxogen free) cable left from when I installed our home theater and wondered if that would work fine for my inverter? I will only be using maybe 100-150W max on the inverter so I think it will be fine right? I just want to make sure so I dont hurt myself or anything. Oh and I would only be using about 8-9ft of cable if that matters.
Also what is the best way to connect it upfront to the battery? Is there a way to connect it to the car's connectors on the battery terminals?
Thanks!
SniperXX is offline   Reply With Quote
Old 06-12-2005, 03:07 AM   #2
markland556's Avatar
markland556 is on a distinguished road
http://www.the12volt.com/info/recwirsz.asp
good table, should apply to what your doing.
markland556 is offline   Reply With Quote
Old 06-12-2005, 06:48 PM   #3
SniperXX's Avatar
Ok from looking @ that I would most likely need 8 gauge wire right?
Oh and what if I ran 2 sets of wires would that work? Basically it would be like combining them. Do you guys know what I mean?
Old 06-12-2005, 07:04 PM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Two sets would work.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 06-12-2005, 07:14 PM   #5
Jahntassa's Avatar
Jahntassa is on a distinguished road
You really only need to run 12v to the battery. You can ground the inverter to the chassis of the car. It's probably better to do so, anyway.
As far as connecting to the battery, make sure you put a fuse within 18 inches of the battery. Unfused connections can be a VERY dangerous thing. If something happened and it shorted out, you could cause a lot of problems. Having a cheapo fuse in the way can only help prevent accidents.
Jahntassa is offline   Reply With Quote
Old 06-12-2005, 11:14 PM   #6
SniperXX's Avatar
Ok thank you for the replys. I am glad to know I can just use this wire (w/ two sets) and not have to spend more on wire when I already have some. How big of a fuse should I use? I was thinking 40ish? What do you guys think and what have people around here used?
Old 06-13-2005, 12:47 AM   #7
im not certain but my guess would be 60.
Old 06-13-2005, 10:51 AM   #8
gommino is on a distinguished road
Read this page for good info about fusing.
Rob.
gommino is offline   Reply With Quote
power issues, will an inverter regulate? blustreak Power Supplies 4 01-23-2005 03:39 PM
how can I wire up power inverter to secondary battery, but turn on when car starts? CrazyModGSR Power Supplies 4 10-29-2004 09:10 AM
FS: VECTOR MAXX 700 Power Inverter muldrick Classified Archive 8 10-23-2004 09:41 PM
Simple Idea for keeping power to inverter while cranking.... syclone477 Power Supplies 1 03-23-2004 10:03 AM
Power Supply & TFT LCD question VegaBOND General Hardware Discussion 0 03-23-2000 07:07 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
