The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 06-19-2005, 09:40 AM   #1
krustydawg's Avatar
My Photos: (0)
Momentary Switch install
Ok I did a search on this but there alot of of differences on where this installs it seams. And I am just not fully understanding it.
I am running a M1-ATX 90w and I would like to add a Momentary Switch for the times to where I don't want the PC to power on.
Do I install the Momentary Switch on the 12v line from the battery?
Or does it go on the acc line?
Or do I just connect it to J8 on the M1-ATX
Im so confused
Krustydawg
Carputer Project: 95% Complete!!
VIA EPIA MII 10000 motherboard | Morex Cubid 3688 Mini-ITX Case | 80Gb 2.5" Seagate Hard Drive | Kingston 512Mb PC2100 DDR Ram | Mini-PS2 USB Keyboard | Microsoft Windows XP SP2 | Lilliput 7" Touchscreen | Rikaline 6010
krustydawg is offline   Reply With Quote
Sponsored Links
Old 06-19-2005, 10:38 AM   #2
Vehicle: 1997 Mitsubishi Eclipse RS-T
My Photos: (0)
heres a post just a few down from yours...hope it helps at least a bit
http://www.mp3car.com/vbulletin/showthread.php?t=52774
Tim97rs is offline   Reply With Quote
Old 06-19-2005, 11:43 AM   #3
273BeLow's Avatar
Vehicle: 1995 Honda Accord Aero Deck
My Photos: (0)
If you want something to *stop* your PC being turned on by ignition you will need a push to make/break switch or a rocker switch, not a momentary.
The easiest way to do it is to put the switch somewhere along the line from the +12v line from the car battery to the M1-ATX, leave it closed and it works as normal open the switch and when you start the car your pc will stay offline.
Current Honda Accord Aero Deck install
http://mp3car.com/vbulletin/showthread.php?t=78717
96' Laguna install
http://www.mp3car.com/vbulletin/showthread.php?t=45365
273BeLow is offline   Reply With Quote
Old 06-19-2005, 11:53 AM   #4
CapitaineFritz's Avatar
Vehicle: 2006 Mazda 3 GT GFX
My Photos: (0)
Well there is a jumper on the M1-ATX (I think it's J8) and we can hook up a switch there so I think it would be a better way !
Anyway, get some wires and a switch (they are like 50¢) and test it That's what I planned to do but right now not a lot of times lol
Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
Trunk fiberglassing in progress...
Need GPS / Aux Input / WiFi
My Corolla Computer
CapitaineFritz is offline   Reply With Quote
Old 06-19-2005, 12:28 PM   #5
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
Like this:
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 06-19-2005, 12:36 PM   #6
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's CarPC Specs
Wiredwrx's Avatar
My Photos: (0)
Actually, the best way to keep your computer from booting is to use the feature built into the M1-ATX, if it has one. I am not very familiar with the M1-ATX< but if you look through the manuel, and see what it says, you can figure it out. Now, if by chance you have no desire to then the next best way to do it is to put an on-off switch in the accessory line of the power supply, AND NOT THE BATTERY LINE. This is simply because, the PS takes about 10 amps or more of power through the battery line, 10 amps is quite allot, and a switch ith that current rating will be big, and bulky. Also, you will have to lengthen the high power wires to get to the switch, and back to the PS, which increases the power loss over the wire. The accessory wire probably carries less then an amp, and most likely about 200 or so milliamps. No need for a high power switch, and extending that wire will not seriously hamper the current carrying capacity. Also, if you take the power from the fuse box, it is probably pretty close to where you are mounting the switch, although not necessarily.
You could also use a relay, but since you asked the question, I would assume there is no reason to increase the complexity of this.
Michael
Wiredwrx is offline   Reply With Quote
Old 06-19-2005, 02:05 PM   #7
d_sellers1's Avatar
Vehicle: 2000 Ford Taurus & 2001 Ford Focus ZX3
My Photos: (0)
If in doubt, experiment. Otherwise, say go with the switch on the ACC line.
I' confused, though. Shouldn't it be a SPDT switch. It's that an ON-OFF swtch. DPDT is ON-OFF-ON. The SPST, I believe, it the momentary but what purpose would it serve? You would have to keep the switch held down in order to have the power flow down the ACC line. Go with the SPDT switch. (If I'm correct on this.)
Derel
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 06-19-2005, 02:33 PM   #8
RS3RS's Avatar
Vehicle: 2003 Ford Focus SVT ZX5, Pitch Black
My Photos: (0)
You don't want a momentary switch. You only want a momentary switch if you're going to hook it up to the motherboard as a power switch. For the power line to the carputer, you're going to want a non-momentary Single Pole, Single Throw (SPST) switch.
RS3RS is offline   Reply With Quote
Old 06-19-2005, 02:58 PM   #9
Bugbyte's Avatar
My Photos: (19)
Derel
SPDT refers to the way the switch works. You can buy this switch as a momentary or permanant (like a light switch). The SP says that this switch is a Single Pole which refers to the set of contacts the switch can work with -in this case a single one. DT refers to double throw, which means there are two positions the switch can be set to.
More info here
Old 06-19-2005, 03:29 PM   #10
d_sellers1's Avatar
My Photos: (0)
Yeah. I knew what I was trying to think of but it just didn't work out right.
Here's a really good site that shows the differencs between switches. It's got pictures too.
http://www.kpsec.freeuk.com/components/switch.htm
Derek
Sponsored Links
Old 06-19-2005, 06:29 PM   #11
krustydawg's Avatar
My Photos: (0)
I'd like to thank you all for your input.
I ended up going to radioshack and buying this switch
Switch
I plan on installing it on the Acc line, as soon as I get all my other wires run.
Again thanks
Krustydawg
Sponsored Links
vB code is On
Trackbacks are Off
xp install to laptop hdd problem thecrow Newbie 8 06-15-2005 03:37 PM
Control switch warnockm Power Supplies 3 03-14-2005 12:26 AM
Recommened Parts for Remote On/OF Switch for an Inverter PapaPrem Power Supplies 4 03-13-2005 04:45 PM
Remote On/OF Switch for an Inverter PapaPrem Newbie 5 03-09-2005 10:54 AM
ATX power switch mtmsol Power Supplies 5 05-13-2001 12:22 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
