Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 06-28-2005, 10:02 PM   #1
Post designing audio system
Hello,
I have been a luker for months reading an searching. I am planning to finish my install this summer, and the audio part is the most important part for me. I would like for the carputer to control all my audio for my system. I believe I have two options, listed below. I am not sure on my best path. I would like for a clean, if possible stealth install with high quality. Can you please tell me if all my facts are right and your opinions? Thanks in advance for your help.
Future Sound System:
(1) JL Audio 500.1 -> (1) 10W6V2
(1) JL Audio 300.4 -> (F) Focal Speakers + (R) undecided.
Need 3 outputs, 1 sub, 1 front, 1 rear.
Using SoundBlaster card PCI/USB:
Pros:
Can control sound through computer
Higher end SoundBlaster cards have about 2V outputs
Can use steering wheel controller
Cons:
Settings are lost during hibernation or standby? Note: I cannot find if this was fixed, as this seems to have been a problem a year ago, not many post recently about this.
Volume set 100% after coming back from hibernation. Note: there are startup scripts to fix this.
Using external Digital Signal Processor:
Have no DIN to install display, will install in glove department. Will use SDIPF for audio from mobo to DSP. 5.1 would be nice during movie playback. Won’t have control of audio volume from steering wheel controller.
DSP options:
Panasonic CYAC300EX ($400)
Pros:
Comes with a remote
Has display for adjustability
2V RCA output
Cons:
Won’t be able to use steering wheel controls
Have to use remote or display to control volume (not big con)
Alpine PXA-H510 ($200)
Pros:
4V
Comes with display???
Con:
No remote
Have to use display to control audio.
Display must accessible for audio adjustments
Apline PXA-H700 ($300)
Pros:
4V output
Cons:
no display
No remote
Alpine PXA-H701 ($395)
Pros:
4V output
Has display (add't $200)
Cons:
no remote
1DeepG is offline   Reply With Quote
Advertisement Sponsored links
Old 06-28-2005, 10:08 PM   #2
MySQL Error
scott_fx's Avatar
i went with a sb pci card and the kxproject drivers and couldn't be happier with the sound. I don't hibernate yet so i don't know if the volume problems have been fixed. If you are willing to spend the money i'd say go with the alpine dsp unit. can't go wrong with that.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 06-29-2005, 11:48 AM   #3
accentsound's Avatar
You may want to check out the Audiobahn ADD51T 5.1 Dsp (9 Volts pre out)
But you are missing one thing especially if you want Sound Quality. Currently there is no way to adjust EQ on each channel independentally. Most High end HU's allow you to adjust the eq fro each channel output.
I know of no SW that allows you to control this in the PC and if you are going to use SPDIF out then the only control that really has any use on the PC is volume and the faders.
If you are really serious about Sound Quality then you must add a EQ to the system design.
accentsound is offline   Reply With Quote
Old 06-29-2005, 08:48 PM   #4
AccentSound... I looked at the Audiobahn unit and not favorable of it since it requires a DIN and I dont have an available one. With the unit hidden, I dont believe I can use the remote. I will look into the EQ, do you have any you recommend?
Can anybody verify that the problems with the Soundblaster still exist?
Help on planning the audio portion of my system ummagawd General Hardware Discussion 1 04-06-2005 03:53 AM
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 05:37 PM
Seperate VGA and S-Video with Audio Fox_Mulder General Hardware Discussion 7 07-01-2004 01:44 AM
Connect hand held MP3 player to car audio system? jasonwood General Hardware Discussion 3 10-30-2001 11:30 PM
Do I have HU or not? -- Factory Audio system helloman General Hardware Discussion 8 03-06-2001 03:11 AM
