Quote: Originally Posted by Emmi
is it not possible if a get a obd1 to do all the things the bc does.? some can do it with obd 2.. dont know if its possilble with obd 1.. if it is what sotfware do i need?
humm..
If you are willing to sacrifice the phone that comes with the car and the headunit, then you can use phoco for gsm. The bc can also be controlled from the indicator stick and you can view most of info next to the odometer
