The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 07-19-2005, 04:12 PM   #1
My Photos: (0)
M1-ATX Pictures of wiring....
Has anyone done a DIY with real pictures on how to wire an M1-ATX. I am not good at reading wiring diagrams, I need pictures, so if anyone has set one up then it would be very helpful. My biggest thing is how the heck do you tap an ignition wire and how do you use a fuse box? Sorry don't know electronics at all.
MikeyTampa is offline   Reply With Quote
Sponsored Links
Old 07-29-2005, 01:43 PM   #2
WiCKeD 5.9L's CarPC Specs
Vehicle: 1998 Jeep Grand Cherokee 5.9L
My Photos: (0)
bump
WiCKeD 5.9L is offline   Reply With Quote
Old 07-29-2005, 02:19 PM   #3
Vehicle: 1993 Toyota 4Runner SR5
My Photos: (0)
Taking real pictures of wiring is not only tedious but also impractical. Every car and installer has different setup.
In order to help you to answer the question, though; you're having problem taping to the ignition? Or, having problem finding the ignition?
EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
edikp is offline   Reply With Quote
Old 07-29-2005, 02:30 PM   #4
Moneyfink's CarPC Specs
Moneyfink's Avatar
Vehicle: 2004 Infiniti G35 Coupe
My Photos: (93)
the thing people have trouble with is the ACC or ignition line with the m1-atx. here is a pic of how to do it:
This is on J-body car I found the pic like 4 minutes after reading your post. You pick a fuse that controls something that can only be turned on if your car is on. I used the windshield wipers. That is tapped into the fuse... the way that i did mine was to wrap the wire around one post of the fuse, then jam it into the fusepanel real tight.
The other two line go straight to the battery, there should be a rubbery thing that you can put a hole through to send wire from the cabin to the engine. Also some people use the car chasis as a ground point. In a few days I will be posting picutres of a few more steps of my carputer and you will see what I am talking about
My OLD carputer page
My NEW carPC
Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
Moneyfink is offline   Reply With Quote
Old 07-29-2005, 02:38 PM   #5
techeros's Avatar
Vehicle: 2003/T3 Tundra Limited
My Photos: (15)
are you refering to this?
http://www.t3tundra.nighttek.com/polk_install/MVC_754F
03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
Carputer Planning |---------*|
Overall Implementation |---------*-|
(Stereo complete)
Computer installed and working
techeros is offline   Reply With Quote
Old 07-29-2005, 02:39 PM   #6
Moneyfink's Avatar
My Photos: (93)
yeah, but on my car its bigger....
My NEW carPC
Old 07-29-2005, 02:48 PM   #7
techeros's Avatar
My Photos: (15)
oh you mus be taking about goin through the stearing column rubber boot
(Stereo complete)
Old 07-29-2005, 03:10 PM   #8
Moneyfink's Avatar
My Photos: (93)
yarrrrgggg----- thats pirate for "yes"
My NEW carPC
Old 07-30-2005, 10:12 AM   #9
techeros's Avatar
My Photos: (15)
rrrrrrrr - thats pirate as well for "Running through the rubber boot is better than having to drill and buy rubber gromets."
(Stereo complete)
Old 08-01-2005, 07:33 AM   #10
Vehicle: 1991 Nissan Pintara (Aussie version of U12 Stanza)
My Photos: (0)
No offence, but that fuse box method is rather dodgy. You'd be better off testing what wire behind the ignition switch has ACC power and then soldering a wire to that.
Oh, and make sure you USE FUSES IN POWER WIRING.
Jono is offline   Reply With Quote
Sponsored Links
Old 08-01-2005, 07:59 AM   #11
Moneyfink's Avatar
My Photos: (93)
yeah, i know it was kinda shady to do it that way, but i've got much bigger concerns right now with my car computer. So im just go do it right after i get it working.
There was no attitude intended in the above statement. I was just admitting that you were right and saying it is something that i had intended to fix in the future. I guess I shouldn't tell people to do it that way, If I don't even plan on keeping it that way
My NEW carPC
Old 08-01-2005, 12:52 PM   #12
wallaceacura's Avatar
Vehicle: 2001 Acura 3.2TL
My Photos: (0)
I think the easiest was it to go to the auto store and get an "add-a-fuse". It's basically a double fuse holder that plugs into an existing fuse and adds an additonal line. Comes prewired with an assortment of fuses. I just don't like the idea of cutting into perfectly good wiring. I've done it twice and it works great. Plus it's reversible.
Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
wallaceacura is offline   Reply With Quote
Old 08-01-2005, 12:55 PM   #13
techeros's Avatar
My Photos: (15)
hate to ask but you got a pic? I think I know what your talking about... kinda like a piggyback?
(Stereo complete)
Old 08-01-2005, 09:13 PM   #14
My Photos: (0)
Hey, fair enough. I would probably do the same thing just to 'mock up' a computer setup for testing. Like you said, I wouldn't recommend it to other people as 'the way to do it'.
If you don't like the idea of cutting into wiring, you should take a serious look at some of the things people have done on the site. I'd class tapping into wires to be one of the most mundane and essential things to do when modifying or adding any electrical systems at all to your car. Do it properly. You can always desolder the wire and tape it up if you want to remove it at any point.
Old 08-02-2005, 03:09 PM   #15
My Photos: (0)
This is like the one I uses. I bought mine at Advance Auto Parts for $7. http://www.partsexpress.com/pe/showd...number=071-580
Why? Why should other's projects necessarily shape the way my project turns out? Why go the trouble and potential risk or damaging a perfectly good wiring harness, not to mention warranty on some cars, when a $7 part does the exact same thing and is 100% reversible? If you don't plan on keeping a car forever, it's nice to have the option to bring the car back to 100% stock. I haven't drilled one hole or spliced into one harness yet. I've used existing grommets, parts like the add-a-circuit and a little creativity to accomplish the same thing.
I can assure you my wiring and soldering skills are up to the task. Sometimes the most "unrefined" solution is the most elegant.
Sponsored Links
vB code is On
Trackbacks are Off
Combining two ATX cables LockNTross Power Supplies 6 09-22-2006 07:51 PM
M1 ATX problems Tompa B Power Supplies 30 09-25-2005 06:39 AM
Whats happens -> M1 ATX combined power overloaded? Me&you Power Supplies 2 05-09-2005 03:28 PM
Specific wiring schematic 4 Optrex DMC40457? sooty LCD/Display 9 07-17-2001 02:11 AM
ATX and AT motherboard Beavis Power Supplies 1 05-10-2001 02:22 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
