Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 08-18-2005, 04:32 PM   #1
Viscouse's Avatar
Viscouse is on a distinguished road
Question Power IGN question
I understand perfectly how to wire up an Opus with the Constant power. Search helped with that. What I could not find was different loads for the ignition wire.
Opus needs Constant & Ignition power sources.
Here's my question.
I have an ignition switched cigarette lighter (which is not used for anything other than power). I already have an XM Commander (needs ignition as well) hooked into it. Can I wire an Opus 120W in there as well? Is the Igntion wire actually used or is it a "sense" wire to let the Opus know the vehicle is turned on & to go ahead & turn on/off.
Thanks...
You know you want to...Worklog
Enjoying v1.0 since it's operational. Aaaawww yeah.
Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
Viscouse is offline   Reply With Quote
Advertisement Sponsored links
Old 08-18-2005, 04:41 PM   #2
strohj's Avatar
strohj is on a distinguished road
its a "sense" wire so that the Opus knows when you turn your car on and off again
so unless your cigarette lighter loses power when you turn the car off... you cant wire it there
strohj is offline   Reply With Quote
Old 08-18-2005, 04:41 PM   #3
ukchris's Avatar
ukchris is on a distinguished road
I mailed Opus and they said there is practically no draw, it is only used for switching. I have mine sharing a connection to my screen, FM modulator and radar detector all through a 7.5A fuse and no problems.
ukchris is offline   Reply With Quote
Old 08-19-2005, 06:00 AM   #4
Viscouse's Avatar
Thank you kindly, that was exactly what I needed to know.
Old 09-16-2005, 01:05 AM   #5
CornToeGoblin's Avatar
CornToeGoblin is on a distinguished road
you could always put in a fuse if you paranoid
2008 Civic... Sound system... then carputer install...
WORK IN PROGRESS
If you look at my avatar closely, you can see a chick with two big knockers....
CornToeGoblin is offline   Reply With Quote
Old 02-19-2006, 08:36 AM   #6
0okami's Avatar
0okami is on a distinguished road
what size fuse? sorry had to ask.
~0okami.Digital
0okami is offline   Reply With Quote
Old 02-19-2006, 10:53 PM   #7
stapan's Avatar
stapan is on a distinguished road
you should absolutely put a fuse if the wire is thinner than the wire you are tapping into. while the opus itself may not draw a lot of power on this line, the purpose of the fuse is to protect the wire itself in case something bad happens and the wire shorts out. remember, this wire is still connected to a hot source of power, and if the wire gets in contact with anything grounded -- whether its twisted sheet metal in a car accident, or just getting disconnected due to shock or vibration and the disconnected end touching something grounded -- you're looking at a serious fire risk without a properly rated fuse. the best would be to use the same wire thickness (so its properly protected by the factory "cig lighter fuse") or if needed use a lower rated cig lighter fuse than factory
stapan is offline   Reply With Quote
Old 02-20-2006, 12:22 AM   #8
0okami's Avatar
so in short, if its a positive/hot/+ wire, always fuse it near the source. correct?
*takes note*
~0okami.Digital
Old 02-20-2006, 01:06 AM   #9
piabu is on a distinguished road
*takes note*
The fuse is actually to protect the battery.
The idea of fusing as near the battery as possible is that in the event of a short-to-GND, the battery would not continue to drain with a large current until it dies (or until something catches fire from a spark or overheat).
By fusing close to the battery, you also reduce the length of "hot" wire that may melt or spark or otherwise be vulnerable.
piabu is offline   Reply With Quote
Old 02-20-2006, 10:02 AM   #10
spuzzdawg is on a distinguished road
I don't know how you worked this out. It's standard practice to fuse electronic items - The first thing a textbook will tell you is that fuses ONLY save electronic components - not people. I guess a battery prob counts as an electronic component but i wouldn't say "the fuse is actually to protect the battery"
My understanding of why the higher power cables are fused close to the battery is to reduce the length of positive cable protuding from the battery in the event the fuse holder came apart. The ideal length therefore would be to place the fuse at a distance less than the closest metal surface to the battery. I think this may be what you were trying to say - but I couldn't really make sense of your comment
Spuzzdawg
spuzzdawg is offline   Reply With Quote
Old 02-20-2006, 10:10 AM   #11
Emo
Emo is on a distinguished road
Nice thread.. learned some things because I need to wire my Opus very soon and I'm freaking out about the whole IGN wire thing.. I have no idea what and where to wire it... If I ready correctly, can I just wire it to the sig lighter and fuse it?
-Emo
Emo is offline   Reply With Quote
Old 02-20-2006, 10:37 AM   #12
0okami's Avatar
-Emo
thats what i understood too. correct us if we are wrong.
~0okami.Digital
Old 02-20-2006, 08:13 PM   #13
xbi0s is on a distinguished road
As long as the cig lighter shuts off when the ign is off -- Some cars have a constant cig lighter
Jim
2005 Acura TL
2005 Honda VTX1800N
PreludePC 2.0 in the making...
Smaller, faster, better...
xbi0s is offline   Reply With Quote
Old 02-20-2006, 11:35 PM   #14
stapan's Avatar
yeah, that's right. spuzzdogg hit the nail on the head as far as fusing it as close to the battery/source as possible, or at least closer than the closest sheet metal.
think of it this way... the wire is like a pipe that always carries water from a source (the battery, or your "cig lighter" wire). the fuse is like a valve on the pipe that when closed, stops water from going through at that point. so lets say the valve is on the pipe a mile after it leaves the source. if the pipe gets a hole in it anywhere in that first mile before the valve, water goes everywhere and you can't shut it off! (sparks, wire possibly catches on fire) closing the valve wouldn't do anything because its after the leak. however, if the valve is right near the source, you can shut it off thereby stopping the leak since the leak is further down the pipe.. the fuse just happens to be a valve that automatically closes if it detects a leak further down.. hope that amkes sense
Old 02-20-2006, 11:39 PM   #15
Emo
yeah that was a good example.. thanks
-Emo
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 11:32 PM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 01:08 AM
The Newbie with another power question nixneon Newbie 1 03-21-2005 12:05 PM
Noob question about power supplies Jagojon3 Newbie 10 03-09-2005 12:35 AM
Question about power and inverters and all that SBmp3 General Hardware Discussion 1 05-01-2003 12:35 AM
