The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 08-21-2005, 12:22 PM   #1
My Photos: (0)
Laptop and Xenarc screen, what power supply to get?!?
Hi guys, just picked up a Xenarc touchscreen which I am going to couple with an old P3/700 laptop I have sitting around. Which power supply or inverter should I get? I already have a Lind converter which plugs into the cigarette lighter, so I would assume I mainly need some kind of inverter.
I have also heard that getting the laptops to standby with engine off is tough. My laptop is ACPI compliant. I would like it to standby when I shut the car down, and start up when I start the car with a defeat switch option to prevent it from starting if I do not want it to.
Thanks guys, I am certainly a newbie and have no idea where to start on the power supply/inverters.
Rick
spinedoc is offline   Reply With Quote
Sponsored Links
Old 08-21-2005, 12:25 PM   #2
My Photos: (0)
Just to help, I would like the following to be powered: The laptop plus the Xenarc screen, various USB devices like bluetooth, wifi, memory card readers, etc etc. I am also adding a direct XM unit with TimeTrax and am not sure if this should go with the power supply or just have its own switched power.
Thanks again, it is going into a 98 Corvette.
Old 08-22-2005, 09:14 AM   #3
NeckPayne's Avatar
Vehicle: 2000 VW Jetta VR6
My Photos: (0)
orthopod, neurosx, chiropracty?
Check out here for getting the startup/shutdown to work. Its usually a matter of hacking the power button on the laptop or hacking a docking station (which is usually preferred).
You already have a converter (DC-DC) for the laptop. So you're asking if you need an inverter for all your peripherals and the display? You can do it either way...an inverter might be easier. A carnetix power supply might also be of use to you, but it might be hard to integrate its ACPI output to your laptop application. Using a converter will require you to do a lot of wiring.
Good luck!
NeckPayne is offline   Reply With Quote
Old 08-22-2005, 09:28 PM   #4
My Photos: (0)
Regardless of whether or not you already have a 12V adapter for the laptop or not (inverter if you don't), you can use an add-a-circuit combined with the female ends of a cigarette adapter Y-splitter to hardwire both the monitor and the laptop to the car's fuse box. Using them couldn't be simpler. Search for my carputer thread in the show off section for a finished 1995 C 280 install and you will see pics and intructions on how to hardwire everything you need using this method.
davis449 is offline   Reply With Quote
Old 02-05-2007, 12:09 PM   #5
My Photos: (0)
You're going to have to spend a little $$ if you want to do it right. I just installed an xenarc screen running in my car - here is the link to my forum. I used a carnetix P-2140 power supply and hacked the power button my my laptop. It has some pretty sweet USB software that runs it and so far I dont have any complaints. Good luck.
toberdorf is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Inverter for laptop and powing xenarc sebberry Power Supplies 10 07-28-2005 05:11 PM
Xenarc Touch screen issue with SONY T-140 Laptop riuster LCD/Display 0 07-22-2005 10:52 AM
Carnetix p1900 and Travla c138 120watt? john_draws Power Supplies 3 05-27-2005 12:42 AM
Stupid Xenarc! It won't turn on when laptop is on or display correct!! PDiddy General Hardware Discussion 18 01-17-2005 07:53 PM
Help!!! Trying to connect Xenarc to my laptop cobra3233 LCD/Display 2 12-07-2004 06:24 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
