Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 08-30-2005, 06:22 PM   #1
Tim97rs is on a distinguished road
SIRIUS vs Xm antennas... the same..?
is there a difference between Sirius and Xm antennas? if connecters are the same, is there any reason why i cant use an antenna made for XM with my Sirius stuff?
please reply only if you KNOW for sure... i appreciate the "i think it wills" and the "i cant see why nots"... but i would prefer to not go running around and making purchases on hunches.
thanks
Tim97rs is offline   Reply With Quote
Old 08-30-2005, 06:34 PM   #2
disregard... just had to go a few pages futher in google....
Old 08-30-2005, 06:36 PM   #3
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
I'm using my XM antenna on my sirius right now.
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 08-30-2005, 06:58 PM   #4
really... humm... notice ANY difference in reception...?
Old 08-30-2005, 07:10 PM   #5
Nah, but mine is stationary, haven't tested mobile.
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 08-31-2005, 02:41 AM   #6
Noticing a little cutting out now and then.
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 08-31-2005, 11:36 AM   #7
Raw Wave
edrex's Avatar
edrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud of
Is there a point to doing that? One gets better reception or something?
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
Quote:
Don't mess with Texas.
It's not nice to pick on retards!
edrex is offline   Reply With Quote
Old 09-02-2005, 12:45 AM   #8
He wanted to know because I assume he either already has an XM antenna, or easier access to one.
And an update, My XM antenna works like **** on my Sirius radio.
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 09-02-2005, 02:57 AM   #9
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
or is it the SIRIUS is just $hit
antimatter is offline   Reply With Quote
Old 09-02-2005, 03:15 AM   #10
lol, no, I like it
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 09-02-2005, 09:33 AM   #11
kiltjim's Avatar
kiltjim is on a distinguished road
I thought there was some diference in the voltages. Like a Sirius system is 6v, and XM is 12v. That might be why you are expereiencing drop out. But I don't have anything to back this up.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 09-02-2005, 12:29 PM   #12
No, its the way the antennas are designed. (I looked it up)
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 09-02-2005, 12:38 PM   #13
sirius has 3 satelites in a higher orbit that beam the signals down at about 45* and 90* angles, while XM is in a lower orbit, has only 2 satelites and beams the signals down at a 30-45 degree angle...
thats the difference in the antennas... they're designed to pick up thier respective signals from a specific anlge if i understood it correctly.
Old 09-02-2005, 10:31 PM   #14
kiltjim's Avatar
But what is the difference between the antennas? If they are designed to pick up at different angles, they would be required to be setup at that given angle. The mobile antennas would work equally as well for both systems, because they are moving.
2000 Subaru OBS
Dell P3 @ 900 Mhz
80GB External HD
Old 09-03-2005, 05:48 PM   #15
fromplanetbob's Avatar
fromplanetbob is on a distinguished road
They are not really designed to pick up different angles of satellite signal. SIRIUS and XM Operate on different frequencies and while they are close enough together in the spectrum that you can use a SIRIUS or XM antenna for either service, the correct antenna for the radio will pick up better reception because it's tuned in. It's like those old tvs with the fine tuning adjustment.
But yes, you can use the antennas from either service on either radio, just expect some degraded signal which means more drop outs.
fromplanetbob is offline   Reply With Quote
Sirius PCR ? Retsaoc General Hardware Discussion 2 03-15-2005 05:55 PM
XM or SIRIUS?? elk29n FrodoPlayer 14 12-07-2004 07:44 PM
Sirius Tuner Like the XM Direct? Geese Car Audio 6 12-07-2004 01:46 AM
Sirius vs. XM...? what up Gee? mindscream Car Audio 12 10-24-2004 04:31 PM
Using an XM direct as an XMPCR dacndar General Hardware Discussion 20 10-17-2004 02:21 AM
