The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Search this Thread Display Modes
Old 09-02-2005, 03:46 PM   #1
Vehicle: 1965 Ford Mustang
My Photos: (0)
PS/2 Port always has power?
Let me start by saying I have a Xenarc SC-3 and am using a wireless Keyboard with PS/2 connector.
When I shutdown the computer or use Hibernate the light on the wireless reciever stays on. Wouldn't it turn off since the computer has shutdown? The USB devices turn off. So does the PS/2 port always have power even with the computer off?
So if I do not cut power to the computer how much of a drain will this put on my car battery?
Confused!
65coupei6 is offline   Reply With Quote
Sponsored Links
Old 09-02-2005, 04:07 PM   #2
MySQL Error
Scouse Monkey's Avatar
Vehicle: Pug 306 & BMW 325i
My Photos: (0)
read up on 5vsb
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 09-02-2005, 04:07 PM   #3
Vehicle: 2002 Audi A4
My Photos: (0)
Confused!
well the PS/2 connector should have power if it's going to do wake on keyboard. Maybe try to turn that option off in the BIOS. I thought this would be a good way to do a remote start up of the computer, but alas, there doesn't seem to be enough power to do that. Well, I am using a USB to PS/2 converter. Can you start your computer remotely by using the keyboard (with the wake on keyboard option)?
rainman1 is offline   Reply With Quote
Old 09-02-2005, 04:08 PM   #4
Vehicle: 1998 Subaru Impreza RSTi Type RA
My Photos: (0)
Your computer should really be hooked up to an accessory line if you're using hibernation
Splinter is offline   Reply With Quote
Old 09-02-2005, 04:16 PM   #5
MySQL Error
My Photos: (0)
Allow me....
your PS2 port will be recieving power off the 5vsb line (5V standby).
This power comes from your PSU to allow devices such as mice and keyboards with power buttons to turn the PC on or bring it out of hibernation or standby.
This can normally be disabled using either a jumper/DIP switch or BIOS setting - look for something to do with mouse/keyboard turning the PC on/waking it up or look for a 5vsb setting.
This can be also be disabled on the Opus as a modification OR you can simply kill all power to the PSU but this will destroy and standby info if you use it (but should not affect hibernation).
providing a 5vsb to a few devices will slowly drain your car battery - over a fair few days - not a problem if you drive it everday. But my worry is that a high constant drain will gradually ruin your battery. Everycar has a slight drain but the larger this gets the more it effects the life of your battery.
Old 09-02-2005, 04:17 PM   #6
MySQL Error
My Photos: (0)
Old 09-02-2005, 04:42 PM   #7
My Photos: (0)
Ok Thanks guys. You learn something new everyday. I don't have that option in my BIOS so I guess power has to be cut all the time.
Old 09-02-2005, 04:44 PM   #8
MySQL Error
My Photos: (0)
did you look for the mouse/ps2/keyboard power option and int he jumpers in the manual? most mobos have it.
Old 09-02-2005, 04:45 PM   #9
MySQL Error
My Photos: (0)
Old 09-02-2005, 05:52 PM   #10
My Photos: (0)
Nope. Acutally Xenarc does not provide a MB manual. Only a quick start guide. The only jumpers that I see on the MB are to clear the CMOS. My BIOS only has the option to change the statup from button only, keyboard, hot key, etc... Nothing to turn it off. I will probably use the UPS dummie S/S controller anyways so it shouldn't matter.
Thanks for the help!
Sponsored Links
Old 09-02-2005, 09:46 PM   #11
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Xenarc doesn't make the motherboard. They build the system and put their name on it.
I don't know what motherboard is in the unit, but you should be able to open up the unit and see what make/model of motherboard it is. Then go to that manufacturer's website and download the manual.
Now that you sparked my curiosity, I did some research. It's very likely that your Xenarc SC3 has the Intel D865GVHZ motherboard. I didn't see a manual, per se, but there are some documents, one of which is a BIOS glossary. That may give you the answer you need.
Good luck.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 09-06-2005, 06:03 PM   #12
My Photos: (0)
Uh, I 'think' that setting the Bios option to NOT start from keyboard should do what you want. So, given your description that might mean setting it to 'button only', if by button they mean the power button.
Best of Luck...
AmigaDude is offline   Reply With Quote
Old 09-06-2005, 06:04 PM   #13
MySQL Error
My Photos: (0)
obviously!
Old 09-06-2005, 06:09 PM   #14
Para Laura
thanatos106's CarPC Specs
thanatos106's Avatar
Vehicle: Xterra SE supercharged
My Photos: (0)
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 09-06-2005, 10:59 PM   #15
The Lavender Tie Just
Made It Obvious
Rafster's CarPC Specs
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
Vehicle: POS 1993 Mercury Sable (Fixed :( )
My Photos: (3)
Quote: Originally Posted by thanatos106
My Motherboards (MSI KJ7N2G, and ECS K7S5A Pro) both have an option to start computer by keyboard.
There are 2 options:
1. Just hit a specific key (A, Y, Tab, CTRL, etc...) and it starts the computer
2. Type a password on your keyboard with the PC off, and it turns it on.
Hope this gives some more explination.
Peace,
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
12v Power Supply at MP3Car.com store mykolJay Power Supplies 6 02-02-2006 09:17 PM
Darn ITPS! Need power help! DJ-FrosT Power Supplies 1 07-16-2005 07:40 PM
Need help with X31 port replicator power switch viguera General Hardware Discussion 1 06-22-2005 11:12 AM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
getting an odd motherboard to power on karmann Power Supplies 13 11-28-2001 05:27 PM
Sponsored Links
Ad Management by RedTyger
