Okay, let me begin by saying I have been reading this board for atleast 6 to 8 months, contemplating an idea of putting a carputer in my RX7. I have finally decided to do it. I built my own computer and did my entire car stereo install, so I am faily knowledgeable once install time comes. Now, my main goal is a pure dolby digital 5.1 surround sound sq setup, mostly for mp3's and maybe gps later. I plan on buying the Xenarc 7" screen and also plan on keeping my Alpine CDA-9853. So here's how I plan on running the system...
Computer -> Alpine h/u -> alpine pxa-h701 processor -> amps -
> Sea Lotus Reference comps. Ok here comes a ton of questions, since im running a h/u do I need a high quality sound card or even one at all, if I do need a souncard what would an efficient one be? Next, I want to run optic cables as well, do i run those from the computer to the h/u than an optic cable from the h/u to the processor, or do i use a special alpine cable from the h/u to the processor, which one would be better? Also I dont have a center channel for 5.1, how do i set that up, or should i just buy a center channel speaker as my stock bose system had one, and I could definetly add one, just not sure if its worth the extra time. I plan on using an Athlon moble xp-m processor 2400+, but I have no idea what board to run. I hear there are problems with the shuttle,biostar and msi boards. Money is really of no object here, I mean within reason, my component speakers were $800 alone, so I dont mind spending a little extra money for the carpc, I really want this to be one hell of a sq system, hence the optic cables and the processing. Leaning towards an opus 150w power supply, but now im starting to look other places, as I am always seeing posts on troubles with them, but i DEFINETLY dont want to use an inverter. Are the choice of cables MONSTER or what other cables would you guys reccomend. Thanks for any info you can provide me with, I am really appreciatve and can help you with any rotary questions
BTW heres a quick pick of the install car. Im sure ill add questions to this thread as I come across them, I plan on ordering parts this weekend, again thanks for any productive input.
