12-09-2005, 07:05 PM
#1
Location: Currently: Dallas, TX. Previously: Belleville, NJ
Vehicle: 1998 Acura 3.2 TL
Please help, trying to make plug for USB hub...
i am trying to make a plug for my USB hub... i have a few leftover plugs from a universal adapter i bought... can someone please verify the polarity of the leads???
the lead on the end is longer than the inner one (right one)... im assuming the longer one should be 5V+??? please verify... here is pic...
12-09-2005, 07:10 PM
#2
Calm Down Or Get A 2 Week Vacation -Love The Forum Policeman
Youve got it all wrong.
In your picture, the bottom pins are connected to the barrel connector (That is the thing that goes into your device.)
You need a continuity tester to see which one of the bottom pins connects to the outside of the barrel, and the inside of the barrel. Then you must decide which one needs what depedning in your device.
Most devices, but it is NOT a rule, is that the inside of the barrel (usually called the pin) is positive, and the outside of the barrel (usually called the shield) is ground.
The connector in your picture could care less how much voltage you send through it, and where the positive and negative are connected to, only your device cares, and it cares a lot.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
#3
Phat Boy
Vehicle: 1998 Hyundai Tiburon FX
test with a multimeter.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
12-09-2005, 07:18 PM
#4
so i test continuity... place voltage on the outside barrel and see which lead that goes too???
yeah i know its a general rule that the outside of the barrell is ground... i just wish these plugs were as universal as they say...
12-09-2005, 07:22 PM
#5
No, do not place voltage on the outside barrel.
Test the continuity to see which pin connectes to which part of the barrel.
Then, look on the cube that power the hub, the one that it came with, and if if it tells you where positive and negative go. Often times the cube has a funny C with a dot in it, and lines leading from the dot to one side of the picture, and a line leading from the C to the other side, and then they have a + or - next to the line. THat way you know which one, the dot is the pin, and the C is the shield, need + and which one needs -.
Michael
12-09-2005, 09:11 PM
#6
USB hub did not come with one.. and they don't make it anymore.. so thats why im trying to make it...
12-09-2005, 09:24 PM
#7
Then you have a problem.
Next thing to do is look on the hub for the C and dot I described. Some times it is on the label on the unit. Also, how do you know that it takes 5 volts, it might take more?
Michael
12-10-2005, 01:37 AM
#8
Michael
most hubs take 5V... i rather underpower it first before i put more power to it...
12-11-2005, 02:50 AM
#9
Vehicle: 2005 Ford Focus ZX3
Michael
Can you open the hub and take a look at the PCB? Look around the power input area on the PCB and see if the input voltage is silkscreened on there.
B Smoov
Project Status: 90% Complete
Next Step: TIVO for Radio
Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
