01-02-2006, 10:41 AM
#1
BMW iBus Users needed!
I just recieved my ibus from Rolfe and am trying to figure out how to connect it to the cd changer. The cd changer plug has three ports while the ibus has 4 prongs. What goes where?!? Please help!
01-03-2006, 07:30 AM
#2
Hi Stevo759
I just joned this forum,
There are 4 pins on the interface:
+12V: (any 12V source switched or unswitched) you can get hold of.
GND: and Ground in the car
IBUS: the Ibus line itself. there are several locations you can get hold of the IBUS line, In US-Models there's usually a pre-wired CD-Changer cable in the trunk, if you want to mount it there...
NTSC: This is for enabling the Rear View Camera Input n the Nav Unit (Pin 17 on the Nav unit) IF YOU HAVE A SOFTWARE LIKE CARMES etc that enables that switch.
Rolf
01-03-2006, 08:34 AM
#3
Vehicle: 2006 Nissan Titan LE
Hey Stevo,
It's been a few months, but I believe this is how it's plugged in.
On your IBUS interface, the pins are marked with IBUS ->+12V -> GND. The CD changer cable has 3 wires.. I believe the brown wire is your GND, the white w/stripe is your IBUS.
If you want to confirm, you can hook up a voltmeter and check the voltages. The IBUS line should read +12V and fluctuate when it's sending messages. The +12V will stay +12V.
2006 Nissan Titan LE Truckputer
[i]No installation thread yet[/I
2002 BMW 330Ci Steel Grey Metallic *Sold!*
Installation Thread
01-03-2006, 09:39 AM
#4
Quote: Originally Posted by immortal
Hey Stevo,
Thanks immortal...so if i dont have a NTSC...then the last pin on the ibus shouldnt be connected to anything right?
01-03-2006, 10:12 AM
#5
right.. just use the 3 you need
got any pics of your install yet?
Installation Thread
01-03-2006, 07:05 PM
#6
All the BMW guys, anyone care to advise me on how the software setup of the ibus is done from start to finish? Also does anyone have the bmw skin with the day and night set up?
leo
01-03-2006, 07:06 PM
#7
Also, how did you guys run sound to the stock amp?
01-03-2006, 11:41 PM
#8
pics are up in the showroom
I used the SVEN4 to go to the stock amp
01-19-2006, 09:28 AM
#9
Vehicle: BMW X5
There is some documentation on how to connect it at http://www.eedesignkits.com, but it is for the USB IBUS interface instead of the serial port one. Take a look at it, it might be helpful...
01-20-2006, 06:25 AM
#10
Can you get the distances detected by the parking sensors through ibus?
01-20-2006, 01:09 PM
#11
Vehicle: 00 BMW 323Ci
Has anyone used this version before?
-Rich
01-25-2006, 09:37 PM
#12
If it works, this little unit beats the hell out of the serial one huh? and its inexensive. nice.
-leo
-Rich
02-07-2006, 12:42 AM
#13
I have been trying to get the iBus adapter to work on my buddy's 2003 330Ci - I am tapping into the CD changer harness in the trunk and have found the +12 and iBus wire. THe trouble is that the iBus wire only reads 0v! I have checked the telephone fuse and it is allright. Any ideas? Any help from the masters will be greatly appreciated!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
