Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 01-27-2006, 02:01 AM   #1
Question LCD screen size for double din opening...???
I tried searching and all that... now it could be because im either an idiot or im just using the wrong keywords... but i cant find the right lcd screen size for a double din opening... i have a 1996 Mitsubishi Eclipse and it has a double din for the headunit... attached is a picture of an eclipse dash (not mines)
as you can see the opening is tilted inwards which makes it good for viewing the lcd screen... but im getting off topic...
Ok well this is the measurements ive taken from my radio bezel (if thats what its called)... W=7.5in H=4.5in and from oposite corner to oposite corner it measures 8.5in... so my question is... what size screen is that... would it be an 8.5in lcd screen... the openeing looks like its kinda wide... so a lcd screen wit an aspect ratio of like 4:3 wouldnt fit... so would it be a widescreen monitor... as u can tell im lost when it comes to this lcd thing... that seemed to be the only thing i couldnt find...
thanx for your help in advance
-J
EclipseGSturbo is offline   Reply With Quote
Advertisement Sponsored links
Old 01-27-2006, 11:55 AM   #2
MySQL Error
MatrixPC's Avatar
all 7" will do fine with little mod.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 01-27-2006, 12:38 PM   #3
im using the 7" lilli. for my double din opening. Width was perfect to the outside of the housing for the screen. it was tall by about a quarter inch, the buttons to the screen end up being covered. This is if you are going ot keep it in its housing. (i made the opening slightly bigger to expose the buttons)
If you intend to pull the screen from the housing, or custom mold it into the dash you can do an 8 in. With an eight inch, The screen part itself will be the size of the double din opening with out the housing.
tratpop is offline   Reply With Quote
Old 01-27-2006, 05:52 PM   #4
So basically what I should get is a 7 inch if i want to keep it in its housing and just mold it into the dash , but if i want to take apart the screen and put it behind the radio trim... i should get an 8inch... how hard would it be to relocate the buttons to another part of the trim... and what exactly are the dimensions of a carputer... would that fit behind the screen where the radio would go... If im still askin newbie questions i apologize but i just would like the input of people that have actually done this b4 i begin to take apart my car and order things... any input would be greatly appreciated... So go wild and tell me what you think i should know, and if anyone has any links to threads i should read... i would appreciate it... thanx alot and hopefully soon i should have a "carputer"
-J
Old 01-27-2006, 05:59 PM   #5
Neither darque nor pervert
DarquePervert's Avatar
You're actually putting the cart before the horse.
You're concerned about fabrication and aesthetics before you even have working equipment.
Get it to function first, then make it look pretty.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 01-28-2006, 12:04 PM   #6
Well im not at all too worried about getting the carputer to function... I am very good with computers and getting it to work doesn't seem to be the hard part... the hard part seems to be making the screen look good and fit right... So basically im just trying to get the hard stuff done first... and Im just looking for the right things to buy... so I can have all my parts b4 i start the install... Plus i was alwayz the guy that had the bodykit b4 the car... lol...
Well everyone thanx for your help... And if you think i should read anything... please let me know... or leave a link... and ill check it out... thanx agaian everyone...
-J
Old 01-30-2006, 12:24 PM   #7
7in or 8in should work fine. I'm installing one into my cousin's car soon. There is a thread on ABS plastics that gives you more than just ABS help. There's urethane as well.
My 2000 Accord Project
DK888 is offline   Reply With Quote
FAQ: VGA vs. Composite (Video) Screens cproaudio The FAQ Emporium 2 12-28-2007 11:45 AM
any feedback info. on Dynamix 7" VGA Touch Screen TFT ??? xtreamvette LCD/Display 29 04-22-2007 03:19 PM
Empty DIN pocket bracket or mount for LCD? PapaPrem General Hardware Discussion 10 09-30-2004 01:47 PM
LCD Text Display for Din opening --Please Help... prerunnerv6 LCD/Display 9 09-24-2002 03:27 PM
