scion tc audio input/output with sub/amp
I'm preparing to put a PC in my 05 Scion tC. My only hang up is the audio. Currently I'm running my stock speakers/6 disc changer and 300w alpine sub hooked up to a kicker kx400.1
What I thought I would do is do away with the H/U since I'm putting a PC in the car and can have all my music on the HDD or add an external drive to play CDs/DVDs. In doing so I figured that the following can be done:
-Get an adapter for the stock speaker system that changes it to RCA, get a RCA to 1/8th adapter...
-Get an RCA to 1/8th adapter for the Sub/Amp as well since it is already running on an RCA...
...Then get a Y-splitter for the PC and hook the two 1/8th cables to it.
My only issues with that set up are...
-Will it put too much stress on the PC?
-Am I going to lose performance? (I imagine so)
-Is there a better way to go? (again, I imagine so)
I'd like to keep things as cheap as possible. Something tells me I might end up having to get another amp for my speakers... which can be expensive.
Everything else isn't an issue for me, I work with PCs everyday and I'm psyched about putting one in my car... GPS, Nightvision camera, my music library, wireless web (in a hotspot of course) all in a car I paid $19.5K for.
I guess you can see I'm willing to spend on the PC, but not so much for an extravagant system.
