03-10-2006, 09:23 PM
#1
mounting case inside car
if this has been asked before a link or more search terms other than "case" or "mount" would be helpful.
So how exactly are people mounting cases in their cars so they don't slide around when they slam on the brakes or something? I've seen the VoomPC case has screw holes, but what do most people do?
I've seen projects where its stuffed into the glove compartment (ugly) as well as people modding the interior of the car to fit a case. However, I'm not really looking to modify the interior too much. (I'm not an expert at this type of stuff nor do I wish to spend the time/cash to do anything too drastic.)
I noticed the Travela cases claim to be able to fit into a DIN or double DIN, but do they come with "mounts" (or whatever the term is) to hold them in place? The pictures that I've seen would make it appear otherwise.
Thanks!
03-11-2006, 01:38 AM
#2
Vehicle: 1998 Nissan Altima
Some people mount them to the floor or wall of their trunk. Other people mount them to their subwoofer box. I have no idea why they mount it to their sub. I don't think it would be too safe for the pc with all the vibrating. If I had a pc to mount in my car, I'd go for the mount on the side of the trunk or behind the dash. I am doing a laptop install in my car, though. Here is an example of a total in dash install.
http://mp3car.com/vbulletin/showthread.php?t=62063
Hope this helps!
1998 Nissan Altima GXE
Sempron 3000+/512 RAM/1000w Sound system/400w inverter
Progress - [//////////]
2005 Chevy Silverado 1500
Currently // Planning
03-11-2006, 04:24 AM
#3
Tainted Love
Vehicle: 2007 Renault Megane
Those little Travlas don't usually fit flush, as they're a bit too long so it would probably stick out of your dash a little.
03-11-2006, 04:50 AM
#4
Raw Wave
 i made that mistake early on, and wasted money on a case i couldn't use.
03-11-2006, 07:28 PM
#5
Vehicle: 1991 VW Jetta
I am using some angle brackets and zip ties. It's a slim pc case, and the brackets hold the case from going anywhere, and the zip ties are there to keep things from moving in extreme stop situations.
03-12-2006, 11:48 PM
#6
thanks for the tips!
03-13-2006, 02:54 AM
#7
Vehicle: 2002 Ford Expedition
velcro
u can also use velcro strips. i heard it works fine, but i wanna try this first!
03-13-2006, 07:44 AM
#8
Neither darque nor pervert
Vehicle: 2003 Toyota Tacoma X-Cab
Since mine is going to be under the seat, mounted with other components, I'm going to cut a piece of MDF to fit, and use a router (think wooodworking here, ya damn geeks!) to cut a recessed well for the Shuttle case to fit into. Figure a 1/4" well shouldn't be to difficult on a 1/2" piece of MDF.
My Worklog
03-13-2006, 09:12 AM
#9
Mdf?
Also, does anyone know why the forum keeps lowercasing the 'd' and 'f' when I type all 3 letters in uppercase, or how to fix this?
03-13-2006, 11:53 AM
#10
Raw Wave
MDF = Medium Density Fibreboard
Kinda like plywood, except it's pressed/glued wood fibers
http://www.design-technology.org/mdf.htm
If your entire post is in caps it'll change the case. If you make a post with something in caps and include some lower case letters somewhere it'll leave the CAPS in CAPS. Anti-AOL-shouting technology, I suppose.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
