Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 04-18-2006, 11:42 PM   #1
yrean's Avatar
yrean is a name known to allyrean is a name known to allyrean is a name known to allyrean is a name known to allyrean is a name known to allyrean is a name known to all
Did I forget something?
Im going to buy some of the peripherals around here but hows this for a start just to get everything up and running and working offline. this will all be installed in the glove box then im making an acrylic lid for it. anyhow did i miss something basic? first ITX im messing with., thanks.
1 x Lilliput 7" VGA Touchscreen 619GL-70NP
- Color: Black [MP3CAR-0022]
- Screen Cleaner: None $254.95
1 x VIA EPIA MII12000 Mini-ITX Mainboard $208.99
1 x 2.5" Hard Drive 60GB Samsung 5400rpm $120.00
1 x Ultra Low Profile 512MB DDR PC3200 RAM $148.99
1 x M2-ATX 160W Intelligent DC-DC PSU
- Optional Cables: None $89.94
1 x BU-353 Waterproof GPS Receiver $75.00
1 x Panasonic Slot Load DVD-ROM/CD-RW Combo Drive 24x24x24
- CD Adapter: Slim Type CDROM/DVDROM/CDRW Adapter [MP3CAR-0083] $87.00
1 x IDE to Mini IDE (2.5" hard drive) cable $12.99
yrean is offline   Reply With Quote
Old 04-19-2006, 08:05 AM   #2
peecee is on a distinguished road
A couple thoughts -
How are you going to connect the touchscreen to the computer? If the epia will be more than 3' away from the lilli, you'll need to get some extension cables - vga and usb.
Depending on where the mobo is, you might want to put a usb hub up front.
I'm guessing you have the software covered because you don't list any.
A case? Maybe not, but you never know.
And you'll need some cables (4ga probably) to run from your car battery to the psu, as well as an in-line fuse for said wires.
Other than that, it generally looks good.
My Worklog
peecee is offline   Reply With Quote
Old 04-19-2006, 10:58 AM   #3
yrean's Avatar
this is going in a 2006 civic SI.
i beleive i have more then enough room to mount everything in the glovebox. then ill finish everything off with a panel to over e verything possibly mount some usbs in it etc. when i send my dash to be coated after im done mounting the lcd casing to it, ill send the glovebox cover also so everything matches.. at least thats the plan so im hoping that i wont need a vga extension cable etc. if so i can pick one up local pretty easy. im definatly gonna need a hub when i start adding stuff..
as for wiring, i was planing on using a fuse at the battery then 4 gauge to a distribution box. (as of yet im not sure if i can use the factory amps and speakers. worse comes to worse, ill have to put in a few amps i have laying around, which then ill swtich from 4 gauge to 2 gauge..
software wise, ill be running xp pro(have a copy already). with a front end of either frodoplayer, centrafuse, roadrunner. im not sure which gps software im running yet. or which is best for what. i need to read more :P
anyhow it sounds like im off to a good start. anyone know a good place in chicago that does plastic coating for a good price? lol
Civic owners, forget building, just get this shamyday Fabrication 20 02-14-2006 11:28 PM
[B]Williamsburg,VA Meet Sunday November 7 @ 11am ->DONT FORGET[/B] chuckctv MP3Car Gatherings 16 11-08-2004 03:38 PM
Forget the shuttle, check out its heatsink Gutter General Hardware Discussion 16 05-31-2002 06:29 PM
Forget soundcards... Dimitris1976 General Hardware Discussion 10 10-26-2001 03:13 AM
forget the tweak programs--- TimW Software & Software Development 2 03-05-2000 07:39 PM
