I am a newb to CarPC's but work as a Sys admin and am quite familiar with
computers. The setup I have in mind requires a large amount of power. I did a
search and found some information but most of it was old (2004 and older)
and most didn't seem to have great success.
If you don't want/need the background info you can skip down to the bottom
where it says -
Finally -- The question.
The Car:
2003 Mercedes C230 Kompressor Coupe
The proposed computer:
Via SP13000
512 mb memory
Seagate Momentus 5400 120GB low power
802.11g
Bluetooth
GPS
DVD/MP3
Maybe Flash for OS (lower power?)
Removable USB drive for DVD/MP3
Surveillance Cameras
The problems:
Power and Drive Space.
Most of you will probably think this is dumb, but that's okay
I need to have a minimum of two if not four cameras in the vehicle.
I have a certified stalker and as cool as it sounds... it's not. So I need
a way to monitor my surroundings in the vehicle at all times. My original
idea was 24 hour monitoring to the CarPC, this I now figure is almost
impossible without a marine battery or leaving the car on. I now have
the following plan.
Home DVR to monitor driveway all day. (Covers while I'm there).
While I'm at work isn't a big deal.
While I'm in the car the alternator will keep the battery charged.
The problem I run into is if I want to leave my house and go to dinner,
a movie, golfing, or anything else. I want my computer during that time
to be able to monitor what is going on around it. These time frames
should be mostly around a couple of hours, but could be as long as
five or six hours.
Can I limit the amount of power the CarPC is using?
I.e. Can I use a 100 watts DC-DC PS or similar and using Laptop
Battery software change the profile to use less processor, disable
all usb devices (the camera's will be PCI) and only power the processor,
ram, hard drive, and PCI card for when the car is off? This would
disable wifi, gps, bluetooth, usb hard drive and other peripherals.
I figure this would lower the power requirements substanially and allow for
some recording time before the battery was drained.
Any suggestions/ideas?
