Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 05-24-2006, 02:02 PM   #1
santisurf's Avatar
New Setup Need Advice on Correct Components.
ok guys i have a mazda protege5 (wagon) and i wanted to install a new carputer i built. my problem is this as follows: i have a double din dash and i wanted a screen which will cover the entire 2 dins.(that solved). i have 3 JL 10W7s which will go in the back with their amp.(that solved) what do i use to power my sides? another amp? ok in regards to power how did you solve the battery drainage problem... i don't want my battery drained... space wont be a problem going to run the entire computer to the back of the car.with just a DVDRW on the front area somehwere... i know alot of extensions!!!
anyhow any advice would be greatly appriciated.
santisurf is offline   Reply With Quote
Old 05-24-2006, 08:31 PM   #2
WarDriver's Avatar
1. What pc car you using?
2. Yes, you will need some sort of amp or headunit to push your "side" speakers. If you run a headunit you will need one with a aux input...but this will require you to relocate the head unit.
3. As for battery drain...why is your battery going dead or are you worried abou this.
4. What interface of DVDRW will you be putting up front? (IDE, USB, Firewire)
5. Don't forget to search. There is tons of info on this site.
-WarDriver-
Real Men Pay With CA$H
My DC to AC Inverter Mod
My Laptop Remote Switch
WarDriver is offline   Reply With Quote
Old 05-24-2006, 11:47 PM   #3
PURDooM's Avatar
You can buy a ATA to usb adapter on ebay for that DVDRW if its a fullsize DVDRW drive. Just an fyi
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 05-26-2006, 11:43 PM   #4
santisurf's Avatar
Not soo fast there sherlock! it wont work... its not a regular DVDRW, its a dell DVDRW which means nothing more to say.. and its not a regular ATA cable..
Old 05-27-2006, 08:19 AM   #5
Neither darque nor pervert
DarquePervert's Avatar
And that, my friends, is why we tell people we need more information to assist in resolving these sorts of problems. There is no need to get all jumpy. You're the one that throws out a bare minimum of information and want a solution.
And trying yourself with interpretive simleys doesn't help either.
Let's start with the simple things:
IS this Dell a desktop or a laptop?
Is the DVDRW a slim drive, like for a laptop (since you say it's not full-size)?
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-27-2006, 05:50 PM   #6
PURDooM's Avatar
If its a laptop drive, you could get one of these:
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
(I bought that one)
That will convert it to ata, which in turn you can convert with another cable to usb...
Old 05-29-2006, 04:03 PM   #7
santisurf's Avatar
(I bought that one)
Well i found my answer on ebay! something alittle more simple!
also power wise.. im going to be running a 300+ Watt Power Inverter... where can i get a relay that will work for my Startup & Shut Down Controler, the inverter, and added preripherals?
thanks guys for all your help.. i promise i will pay you allllll back... just ask away if u need anything computerwise... (software Cough Cough)
Small Car, budget complete setup advice Scouse Monkey Car Audio 16 07-18-2007 08:10 AM
New Setup - Simultaneous Video and Audio? DeathMetal Newbie 4 01-01-2006 06:25 PM
Need Advice for a Dell SX270 setup xs10x Power Supplies 5 12-09-2005 11:36 AM
Doing a carpc setup, questions/help Punisher General MP3Car Discussion 1 08-28-2005 12:44 PM
help with my wifi setup? ŠuTcH Wireless Communications 4 12-05-2004 11:10 PM
