Remote wire and input is simply +12VDC (no ground needed).
It is similiar to a relay. When the input receives the +12VDC (when you turn on the car), the relay makes the connection between the power and ground on the amp thus turning it on.
If your PSU has a built-in amp thump thingie that's too cool. I'm actually going to need to hook up a
delayed relay timer to delay the input to the remote of the amp until after the soundcard on the computer has initialized in order to prevent the thump.
I'll put the +12VDC IGN wire in to the relay and after the timer has elapsed it will close the circuit and pass the voltage in to the amp remote input.
Derek
