Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 05-29-2006, 04:28 AM   #1
P4 - not mini?
trying to get into the scene and have found alot of interesting things but one thing i haven't seen at all (unless it was like a 266) is someone running with anything other than a mini board.
i currently have a desktop that will be replaced and would like to use in my truck (plenty of room under the rear bench). this is a P4 1.3G (older pin style). from my research it looks like i would need the 150W PSU.
Guess the real question is would it work and also power issues with such a power hog chip - would i need to address power issues like installing a second battery?
digitalslave is offline   Reply With Quote
Old 05-29-2006, 06:59 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
As long as you have the means to power it, you can run anything you want.
I suggest reading as much as you can in the FAQ Emporium to gain information. Also, check out the Show Off Your Project forum for inspiration.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 02:24 AM
'02 Honda Civic P4 mini barebone hondapc Worklogs 2 05-22-2006 06:22 PM
Testing the waters: mini itx p4 mobo and cpu EsKALad Classified Archive 15 12-31-2005 09:46 PM
P4 Mini Itx Mobo with Agp Slot CJ8501 General Hardware Discussion 5 03-18-2005 12:34 PM
no mini itx between 1ghz eden and P4 2.4Ghz?! Henke General Hardware Discussion 9 02-04-2004 05:11 PM
