Quote: Originally Posted by rabbitman007
I am looking into placing a computer in my car. I am caught between an ATX or ITX chassis. I want to include either a 15" touchscreen or regular 15" LCD in the car. The computer can be powered DC through the special power suppliy, but how do i power the screen? any suggestions. The same goes for an external DVD burner. What are my options?
Your first option is the
FAQ Emporium, which has answers to 99% of questions you might have about a vehicle PC.
For the LCD, look for model that has a transformer-style power brick, as you can likely produce the voltage needed with a DC-DC PSU. And 15" screen is HUGE for a vehicle, unless you drive a bus.
External slim DVD burner can be powered off the firewire or USB bus, although USB would require two USB connections (one for power, one for data)
Quote:
Also, with my car I am looking for a patch to monitor all of the guages (speed, tach, odometer, fuel, oil, water, etc) through the computer. However the car is an 83, with no ECU (car computer). Any ideas on what to do?
Get a newer engine or a relay board, software and sensors, then be prepared to do some coding. The newer engine option is a lot easier.
You need to make that decision.
