Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 06-20-2006, 10:40 AM   #1
MrGee's Avatar
MrGee is on a distinguished road
Power Supply
Hey guys,
Here's another newb question, I just finished putting together my Via EPIA M it boots up and everything seems good with a normal 120V Power supply. Now I'm looking to wire my car up so that I could test to see if it works in there... But I ran into a problem that I didn't find any solutions too (I did look) I'm looking at purchasing hte OPUS 150W power supply even though my comp won't use that much power I am going this route so I could expand easily later if I would want too... Here is my delema... I'm not sure if I need both a regulator such as the: http://www.mp3car.com/store/product_...products_id=94
And a Power Supply such as:
http://www.mp3car.com/store/product_...products_id=32
Or could I just use the power supply on it's own? It doesn't mention anything about a regulator being built into the power supply this is why I asked this question... Thanks in advance for the help!
MrGee is offline   Reply With Quote
Old 06-20-2006, 10:50 AM   #2
evandude's Avatar
evandude is on a distinguished road
the opus supply regulates all its outputs, there is no need for an additional regulator.
The only dc-dc's that need additional regulators are the mini-box supplies like the PW-200, which are nothing but falsely advertised junk; all the "real" dc-dc ATX supplies like opus, M1-ATX, M2-ATX, DSATX have everything you need in and of themselves.
But don't take it from me! here's a quote from a real, live newbie:
Quote: Originally Posted by Viscouse
I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
eegeek.net
evandude is offline   Reply With Quote
Old 06-20-2006, 10:53 AM   #3
MrGee's Avatar
Thx a lot evandude... Gonna order the Opus supply now... I just didn't want to hook up the power supply and have it get shorted out due to no regulator being installed and gettign the voltage jump...
Wish me luck on installation this may be interesting... lol
P.S. Anyone know a local place I could pick up an OPUS 150W DC-DC power supply in Toronto, Canada? thx
Old 06-20-2006, 11:26 AM   #4
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Considering the highly specialized nature of these products and the fact that it's a very samll niche market, I wouldn't expect to find a physical store carrying Opus units or any other products that are specific to vehicle PCs.
I could be wrong....
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 06-20-2006, 11:28 AM   #5
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
just an FYI - and you may have already done this, just wanted to give a heads up since some people are running into issues.
your computer may put out a total of less than 150 watts, but have you checked each rail for it's power consumption?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 06-20-2006, 11:30 AM   #6
MrGee's Avatar
Very good point... Even finding my ITX mobo was a real pain and took a lot of time.... But hopefully I could find one if I don't find one by today I'm just going to order from Mp3car's store most likely...
Old 06-21-2006, 05:21 PM   #7
MrGee's Avatar
Not sure what you mean by this exactly? Would the board not only draw as much power as is needed as long as the right voltage rails are used? As far as I know to much voltage will damage the electronics but as long as voltage is ok it only pulls what is needed... I could be completely wrong and plz tell me if I am... but to be honest I didn't exactly understand what you meant in the post above, I know my computer uses less then 150Watts all together is this bad?
I think I'm really confused about something...
Old 06-21-2006, 05:24 PM   #8
MrGee's Avatar
The reason I want to get the 150W opus is because in the future once everything is in and working I will eventually want to upgrade it, figure would be easier upgrading again without having to buy another power supply...
Old 06-21-2006, 05:34 PM   #9
_
ok - you need to learn what I'm talking about when I mention the different rails.
This is something that is critical to installing your computer and powering it adequately.
http://www.mp3car.com/vbulletin/faq-emporium/68636-faq-will-insert-psu-model-power-supply-work-my-system.html
this thread will help explain a bit of that.
you aren't only powering a 12v rail, there's also a 5v rail and a 3.3v rail that you need to consider.
Jan Bennett
Old 06-21-2006, 05:44 PM   #10
MrGee's Avatar
http://www.mp3car.com/vbulletin/showthread.php?t=68636
ok so... To better understand this, I understand there are more rails then just a 12V but I don't fully understand what everything means, this is the motherboard I have for the carPC: http://www.via.com.tw/en/products/ma...herboard_id=81
I know it's a C3 EBGA 1Ghz chip but on the site you gave there is multiple a 1.0G and a 1.0T
C3-1.0G C3-1.0T
(EBGA) (EBGA)
the 1.0T is at the very bottom of the list... I've looked at the Mobo but can't see anything that will tell me which of these two it is... as you can see there is a difference between the two.
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
REVIEW::220 Watt DC-DC Power Supply: DSATX seabeggar69 Power Supplies 4 03-20-2006 05:53 PM
Shuttle G5 1100h and Opus Power Supply Caelric Power Supplies 9 11-16-2005 05:13 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
Power Supply Options? Optikal Power Supplies 9 06-26-2004 06:46 AM
