06-22-2006, 04:09 AM
#1
Will this work?
2007 Camry LE V6
2 Cigarette Lighters clearly labled for 12V 120Watts combined
HP Pavillion ze5345us Laptop with USB GPS dongle
connected to one Lighter using Cig Lighter Adapter:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=6862481257
Note: standard AC wall adapter for this laptop is only 90watts max
8" LCD VGA touchscreen
connected to second Lighter with included Cig Ligher Adapter
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=9742082504
I'm assuming that since laptop's LCD will always be off, it would be less power needed for it.
So around 10 to 12 watts for LCD and less than 90 watts for Laptop.
Will this work? Am I totally clueless?
06-22-2006, 01:54 PM
#2
Neither darque nor pervert
Sure.
My Worklog
06-22-2006, 01:55 PM
#3
_
lol
aww hell, why not?
06-22-2006, 02:03 PM
#4
Raw Wave
Are you sure you want to power both off cig lighters? I can see doing that with the laptop if neccesary since you will likely be using it in and out of the car. As for the screen though, you might want to find a more permanent power source (i.e. the ignition line) so that your install is a little cleaner and you leave one of your cig lighters for other things like cell phone chargers.
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
Quote:
Don't mess with Texas.
It's not nice to pick on retards!
06-22-2006, 05:04 PM
#5
The cellphone recharges with the USB data cable.
06-22-2006, 05:06 PM
#6
_
how long does that take compared to the regular charger though?
06-26-2006, 07:55 PM
#7
The laptop cig power adapter works great. GPS works great. But now i'm not sure how to remotely turn on the laptop that's going under the passenger car seat without reaching under there, flipping open the lcd and pushing the power button.
Any ideas or suggestions?
06-26-2006, 07:59 PM
#8
Unregistered User
Why not?
ODYSSEY
Quote: Originally Posted by Tidder
All information expressed in this post is my opinion, and should not be regarded as a statement of fact. Digital-Car UK|
(\__/)
(")_(")
06-26-2006, 09:22 PM
#9
FLAC is for flaccid
Quote: Originally Posted by DarquePervert
Sure.
I'll expand on Darque's, um, limited, response. ;-)
It will likely work. However, if the devices draw too much current, then a fuse will likely blow somewhere in the car, and everything will stop working until that fuse is replaced.
If I were you, I'd try it. If a fuse blows, you have three options...decrease the number of devices you're trying to power, wire the devices more permanently with larger wire, or buy an aftermarket cigarette lighter receptacle and run a larger wire from your battery to it.
An amateur built the Ark. The Titanic was built by professionals.
07-24-2006, 10:48 PM
#10
Jay, have you installed the 8" LCD screen yet?
07-25-2006, 06:23 AM
#11
I just said it would work... Not that you wouldn't encounter some problems.
You've stumbled upon one of the biggest downsides to a laptop installation: starting it up with the ignition....
Someoen made a startup unit for laptops. Others have a circuit with two relays.
Others use a startup controller and hack into the power button (which renders teh laptop useless anywhere but the car)
Others use WOR or WOL circuits to startup the laptop.
There are options, but none are particularly easy.
My Worklog
03-08-2007, 12:26 PM
#12
Okay got my 7" LCD touchscreen working with another modded 99 cent cigarette liter adapter. All i did was replace the cheap fuse with another cheap fuse. Removed the small circuit board from the cigarette liter. And twisted the red wire with red wire, black wire with black wire. WALAH! Cheap but effective car adapter for my 12V touchscreen.
Now to look at all my options in building a cheap but powerful "enough" carputer to replace my laptop.
03-08-2007, 12:57 PM
#13
FLAC is for flaccid
You should check out the specs on your touchscreen. Your car's electrical system will produce between 13 and 15V while running, and 11 -12V with the key off. So, the touchscreen needs to be capable of running on an input from 11-15V or so. If it's not, and you've wired it directly to the car's electrical system, you're running the risk of a voltage surge/drop (which can occur when you start/stop the car, etc.) ruining your screen. The worst thing is, such a voltage surge could really happen at any time, and with little to no warning...and your screen would be toast.
If I were you, I'd protect the investment I made the screen by going to WalMart and buying the $14 (yes, just $14) 12V, 2A (2000mA) car power adapter they have for sale. This will provide your screen with regulated 12V power, and is really cheap insurance that will help protect your investment.
I'll post a link if you need one.
03-12-2007, 11:50 AM
#14
I think i'll take your advise, and get it. thx
| Thread Tools |
| Display Modes |
Linear Mode
