Quote:
Quote:- USB HUB (4 ports, individually powered, 7.5 volts)
One question I have here is how to get 7.5 volts to this hub?
Most PSUs put out only 12V, 5V and, 3.3V.
Well as it is a laptop I was just think about using some car adapters for
both the laptop (16v) and the usb hub (7.5v), as they both seem to
have voltages that are pretty common for 'car lighter plug' style adapters.
I was just just gonna cut the plug itself off and connect it to switched
12v with an in-line fuse. The laptop adapter would have a capacitor build
in to help stabilize the voltage, but the other one might be a problem.
As the laptop battery should help the 'puter survive the cracking I would
just need a way to power an external optical drive and to stabilize the current for the 7.5v hence the idea of the 2nd (small) battery, with the
added benefit of not risking running the primary battery down.
Just would need a start/shutdown controller that way, I noticed a nice
tread using pins 4 & 8 on the comport, might look into that or just go for
the dashwerks dssc.
Quote:
Quote:
- GPS Receiver on PS/2
Why PS/2? The BU-353 (USB) is apparently a MUCH better GPS receiver than it;s serial counterpart.
I'll look into that, originally the reason for the serial one was that when listing
the peripherals I need I was running out of usb-ports fast (even with the
4-port hub).
-basically :
1 usb on laptop -> hub
hub #1 : Touchscreen
hub #2 : Soundcard
hub #3 : Optical Drive
hub #4 : USB Dash connector
But if I kill the fm/tv tuner I might use that PCMCIA slot for a PCMCIA to USB card that might give me another 2 or 4 usb ports. That way the PS/2 might be used to help power that optical drive ... just an idea.
I'll just have to wait till they get the external version of the HQCT version done :-(
Quote:
Quote:
- Tv/Radio Tuner PCMCIA Card
Good luck with this one. From what I have gathered, there's not really a good FM tuner card out right now other than the HQCT
See before, ...
Quote:
I can't blame you. Unlike Enforcer, I don't have a HU in my car and haven't for 3 years or so. If it's a permanent fixture in your car, and not a modular style CarPC, there's no reason for it to go in and out of the car.
It is staying there, I don't want the hassle with the wife, about bring the
stuff back in the house, besides what is the use of an LCD-less Laptop anyway (beside connecting it to a Lilli :-)
Just need a line driver it seems, thx for pointing me here in the right direction ....
For the optical drive question, I haved really found suggestions but
I guess the glove compartment is as good as any place ....
Quote:
Most DC-DC PSUs survive crank without an issue. no second battery needed, and definitely not deep-cycle, though a single deep cycle wouldn't hurt.
See up for the power options that I had in mind, but I'm willing to entertain
the idea of a psu, but as the laptop doesn't have a standard ATX power
block I fail to see how I would get power to the motherboard of the
T20 ... Maybe I slept during a class and I need a refresher course
Quote:
Hope this helped at least some!
You are exactly what the doctor ordered, it helped more than you probably
realized, I just hope we can keep this discussion goin :-)
Sincerely,
Jurgen
