The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 08-22-2006, 06:50 PM   #1
we87's CarPC Specs
we87's Avatar
Vehicle: '02 Trailblazer
My Photos: (0)
Delay Power On Circuit - Need Help
I have my carputer installed, and I am using an 600watt Inverter to power the 300watt ATX Power Supply that I use....
I built the "Ghetto SDC" shutdown controller for my inverter to start up and shut down with the car's ignition, and it all works flawlessly....excecpt for one minor thing: My inverter doesnt survive crank. So what happens when I start my car, the inverter comes on and while the start is being cranked for that few seconds, the inverter thinks the battery is dead and the led goes from green to red and the inverter no longer supplies power to the computer. I have to manually switch the inverter off and then back on again.
So what I need is some sort of a way to delay the power going to the inverter for a few seconds, that way I can let my car fully start itself before the inverter kicks on.
Can anybody point me in the right direction? What do I need? How can I get this done....
Many thanks in advance!
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Everything is in the car and working.
I painted the cilpboard mount and it looks good.
Shutdown/Startup is working excellent!
View My Progress Here
we87 is offline   Reply With Quote
Sponsored Links
Old 08-22-2006, 11:20 PM   #2
yrean's Avatar
Vehicle: '06 SI
My Photos: (0)
it sounds like your inverter is getting its power from your accessory(lighter outlet) so when you crank the car it drops the power. If this is the case grab your 12v, straight from the battery itself and see, if it is right to the battery, you might be able to put a small cap inline. so when the battery takes the drain from start, the cap still has power charged in it so you wont drop.
not sure your scenario just the first couple of things that popped in my head
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
yrean is offline   Reply With Quote
Old 08-23-2006, 01:57 AM   #3
we87's CarPC Specs
we87's Avatar
My Photos: (0)
The inline cap is a great idea... I wonder if that would work though?
I dont use a cig lighter for power, but it doesnt come straight from the battery either. I have a 2002 Chevy Trailblazer LS, and in the back under the rear seats there is a fuse box with a 12volt bolt that I think (99% sure) that the wire is coming straight from the battery......but.....i could be wrong....
Also what I noticed is if nothing is plugged into the inverter, it runs fine during crank. But when something is plugged into it, it dies...
Carputer Progress
[||||||||||] 100%
Finally Installed!!
Old 08-23-2006, 07:23 AM   #4
Queenambeach's Avatar
My Photos: (0)
Cool
Same problem I have. Inverter powers directly from the battery and doesn't survive crank.
Queenambeach is offline   Reply With Quote
Old 08-23-2006, 08:04 AM   #5
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Inverters rarely survive crank.
Search the forums for TANK CIRCUIT for one potential solution.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 08-23-2006, 08:16 AM   #6
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (22)
DP's right. Some survive crank, some don't. Even the same model may survive crank on one setup, but not on the other.
It sounds like you are pulling too much power from the inverter to allow it to survive crank, since it seems to do so with no load on it.
I've seen automotive relays with built in delay timers on them. Try a Google for them. But remember that you are going to either have to get on e that is rated for the load, or build a circuit that triggers higher amperage relays after startup.
I have a delay-on circuit that I use in my car for a different purpose. I bought it as a kit and soldered it together. It triggers a relay after startup. Can't remember where I bought it, but just do a search and you'll find lots of them.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Micro Star Motherboard Problems with Power Switch/BIOS Sidewalksalvage General Hardware Discussion 3 06-26-2006 12:40 PM
Speaker Popping Noise (delay circuit options?), Line Drivers to boost volume which 1? SuprchargdMazda General Hardware Discussion 9 05-26-2006 07:57 PM
power retracting mirror circuit Cypher333 Hardware Development 7 04-02-2006 04:49 PM
FAQ: Tank Circuits (Adding a Second Battery) starfox The FAQ Emporium 0 01-08-2004 08:23 AM
Anyone haveing probs with the relay delay circuit Synx Power Supplies 1 10-01-2001 04:15 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
