Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 09-07-2006, 02:50 PM   #1
Nissan Versa
So i got one of the new Nissan Versas and i am trying to find a spot for the LCD, I do not want to take out the stock radio, any ideas?
landonb16 is offline   Reply With Quote
Old 09-07-2006, 03:44 PM   #2
NeoMatrixJR's Avatar
What's the little cubby right above the radio? I have an altima and I know there's some similar space behind my dash (no cool cubby in mine ) and it wouldn't be deep enough, but if yours is you could put a flip up screen here, otherwise I'd say right above the cupholders somehow.
NeoMatrixJR is offline   Reply With Quote
Old 09-07-2006, 04:23 PM   #3
The depth of that cubby hole is about the size of a cd case. I was thinking that i could put a fold out there, but it might not be big enough.
Old 09-07-2006, 04:34 PM   #4
That sounds about as big as mine would be if there was an actual slot in the dash, but there's no real way to tell until you take it apart.
Old 09-07-2006, 04:48 PM   #5
yeah i figured that. Little scared, only had the car for 16 days.
Old 09-09-2006, 06:55 PM   #6
This should be its sister model the Renault Megane
ecsk2 is offline   Reply With Quote
Old 09-10-2006, 11:51 PM   #7
sister?
Mine looks like the 1920 T model compared to this...
Old 09-12-2006, 01:08 PM   #8
Three options, really:
- Get a single-din slideout unit from digitalww.com and put it in the cubby above the radio
- Get a single-din aftermarket headunit, put it in the cubby above the radio. Put the 7" LCD in the dash where the two-din radio is now.
- Sacrifice the cupholder area and fabricate the LCD into that section of the console.
I'd go with the first option for two reasons:
- If that is a single DIN up there, it makes for an easy install.
- It makes it easy to put back to "normal" when you are finished with the car.
- It's not readily apparent that an LCD is in your car. You can tuck it away and it's hard to see what that is. Double bonus if you can keep the cubby cover in tact.
If you're adventurous, you could go with option 2. Would look the most stock, but would require not using your factory headunit.
Option 3 is really valid only if you like fabricating and don't care about returning the car to stock form before reselling it.
My $.02
Geese is offline   Reply With Quote
Old 09-12-2006, 01:10 PM   #9
Ok, super bonus option:
- Relocate the AC controls to the cupholder area, and fabricate the LCD into the space where the AC controls were.
Old 11-03-2006, 11:48 AM   #10
I like to add a Legacy LDNTV65U unit to my Versa. Would a standard double din reciever replace the stock unit?
Here's a pic of the Legacy.
LMS79 is offline   Reply With Quote
Old 01-25-2007, 02:31 PM   #11
Update!
so its been in for about 2 1/2 months now and its works great, here are some pics
http://picasaweb.google.com/landonb/...33168410021554
http://picasaweb.google.com/landonb/...33241424465634
I am going to redue it when it gets warm out, i needed to sand it a little better then i did, but other then that it is great, Thanks guys for all of your help!
Carputer for 2005 Nissan Altima checksum Newbie 7 03-24-2006 01:08 PM
Nissan skin djR1SpecV General MP3Car Discussion 6 01-11-2006 10:25 AM
new nissan software? dim-8 Software & Software Development 2 02-15-2005 07:19 PM
Nissan Xterra XPuter Stage 1 OKC-X Show off your project 10 04-02-2003 11:00 AM
