Quote: Originally Posted by
Wilsman00
VoomPC Car PC Enclosure
(placed in the glovebox of my miata)
how are you going to secure it? do you know for sure that you have enough room? enough room including all cables?
Quote:
VIA EPIA MII10000
(with IDE riser to 2 IDE ports)
as stated earlier, don't think the voom case can hold a riser...besides that, what do you need two ide ports for?
Quote:
WD 120gig 5400rpm Laptop HD
(need IDE converter to run this HD)
look around, they exist and are readily avaliable.
Quote:
Linksys Wireless G Card (already own, might have to buy new antenna)
is this for the IDE ports? I don't believe it would fit in the case, let alone does that case have room on the back side of it for the cables and antenna to exit from?
Quote:
Creative Audigy 2 ZS (already own)
how do you plan on going from this card to your stereo?
Quote:
LiteOn 16x DVD Drive
(plan on running cables out case and hand/place dvd-rom right near case)
how are you going to secure this? is this a full size drive or a slim laptop drive? if it's a slim drive, do you have a converter for the cables? are you running an external case? do you have room for this, all of the cables, and the motherboard in the glove box?
Quote:
XENARC 700IDT Indash 7" LCD Touchscreen (don't like a big steal me target)
installed properly, just about everything can be hidden and well integrated. Do you know for sure that you have the depth that this unit would require behind your dash?
Welcome to the boards. It looks like you have done a good deal of research and have thought out yoru plans. The points I have mentioned are points that most people overlook in their planning.
Let us know if you hae any questions!
