The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Display Modes
Old 12-31-2006, 05:01 PM   #1
Vehicle: 2007 Scion tC
My Photos: (4)
This is where is starts. tC CarPC
**Okay, I am a car audio idiot, and forum dumb also.**
So with that said, I stumbled upon bembowe's CarPC in his midnight blue tC and I thought it was hot. So I started researching. I came up with a parts list, and I made a diagram.
I would just like your advice, and your inputs, did I draw anything wrong? (I'm sure I did) Just tell me how to correct it and if my parts list sucks or the information is incorrect, please give me suggestions. I have not purchased any parts yet since I'm not back in the states. This is for: 2007 Scion tC.
Thanks in advance!
Help?
aznlaoboi07 is offline   Reply With Quote
Sponsored Links
Old 12-31-2006, 10:52 PM   #2
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
Insert a fuse close to the battery and use distro blocks to distribute +12 and ground. You can tap into your cigarrete lighter wire or somewhere in your fuse box for the ignition lead.
treetop777 is offline   Reply With Quote
Old 01-01-2007, 12:35 AM   #3
MRVJ245's Avatar
Vehicle: 1973 Chrysler VJ Valiant
My Photos: (0)
looks good, except for a fuse on the main positive feed, and a missing fused distro block (can never be too safe)
also you forgot the USB/Serial cable from the Touchscreen to the main board
For Bootscreens click Here
MRVJ245 is offline   Reply With Quote
Old 01-01-2007, 10:20 AM   #4
My Photos: (4)
how do i get power to the monitor?
Old 01-01-2007, 10:31 AM   #5
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
With wire...
Seriously...
Search the forums. This is something that has been covered many, many times.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 01-01-2007, 12:48 PM   #6
My Photos: (4)
okay.. my bad
Old 01-02-2007, 12:14 PM   #7
mwmcginn's CarPC Specs
mwmcginn's Avatar
Vehicle: 2006 Honda Accord
My Photos: (0)
New here too, Thanks for posting such a detailed plan, this will help us all. I am going with a laptop setup, which you may think about with the costs of components that you are getting plus the addition of an OS.
Mike M
2006 Accord VP Sedan
My worklog
http://www.mp3car.com/vbulletin/work...-dads-car.html
mwmcginn is offline   Reply With Quote
Old 01-06-2007, 06:15 PM   #8
My Photos: (4)
I updated the diagram with suggestions.. anything else i missed?
Old 01-06-2007, 07:22 PM   #9
treetop777's Avatar
My Photos: (0)
Up there by the monitor, you don't need a relay, you can connect the "turn-on" wire directly to the M2. Also, you can power the monitor by taping into the M2's +12 and ground output.
EDIT: Good luck with that M2, it's a toss-up whether it will work first time around..
Old 01-07-2007, 10:17 AM   #10
My Photos: (4)
thanks treetop i see what you're sayin.
Sponsored Links
vB code is On
Trackbacks are Off
2004 Accord navigation with carPC blazer563 Newbie 12 02-14-2008 10:33 PM
2007 Scion tC - CarPC DONE! mike6789 Show off your project 21 08-31-2007 12:01 PM
carpc with name brand monitor fasteddie Input Devices 5 08-25-2006 07:09 AM
Problems with BootSkin and CarPC Red GTi VR6 WinNT Based 7 08-02-2006 10:06 PM
muting head unit audio when carPC outputs audio augieman General Hardware Discussion 1 04-18-2006 07:35 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
