Quote: Originally Posted by
JC-S60
Correction: minimizing write access. Reading you can do as much as you want. Use a separate usb drive to store logs ans you'll be fine.
Here are some instructions on making XP solid as a rock on flash devices:
http://osf1.gmu.edu/~sfiorito/eXPinstall.htm
Thanks for the link.
I have pondering the use of flash devices since it was mentioned - are you referring to something like the Sandisk SD cards. Something like that would make sense, I have a 2GB one in my phone, however I understand that they have a limited life span, or is this down to manufacturer?
JC-S60
The base model (1.2Ghz, 256Mb, 40Gb, Internal PSU and USB-IO) with cables would be €780.00
If you add AM/FM/RDS radio and integrated GPS hardware, that would be €1040.00
No screen is included in the above. The 7" Touchscreen option (Xenarc black with sunshield) is €385.00
A special shock-proof* harddrive of 40Gb would be €120.00 extra
A solid state harddisk for the OS and applications of 1Gb (on top of a normal 2.5" harddrive for storage) would be €160.00 (64Mb - 2Gb possible)
Sounds good....
I need at least 80Gb of storage - we will be storing a stack of music, all our photos and videos as well as several GB of maps and satellite images.
I already have a GPS mouse mounted on the roof.
I would want at least an 8" screen - have you tried looking at a map on a computer whilst bouncing around off road?
I would also want at least 512-1Gb of RAM (bearing in mind no paging file) and a half decent graphics card for 3d rendering of routes.
What are the dimensions of your case?
