Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 01-25-2007, 07:15 PM   #1
Charles1's Avatar
Smile Help with power
I am about to purchase the following.
SolidLogic 3688 Mini-ITX Car System
but under the power it gives me the choise to get the m2-atx power supply. My question is I see the sell power adapters to plug in wall. so the question is which if any can work witht the m2 atx or is it only auto use only?
I see they have an 80 watt auto with adapter but it sounds weak but is 80 watts enough to power a dvd,gps,one hdd and? well let me know asap thanks. Reason I ask is because sometuimes i want to use the pc outside the car and have the means to power it outside the car. thanks
ccortes@smscorp.com
Charles1 is offline   Reply With Quote
Advertisement Sponsored links
Old 01-25-2007, 08:17 PM   #2
M2 and M1-ATXs are for automotive use only. You can always use a spare power supply for a pc, if you have one, when you need to use it indoors.
volum3rider is offline   Reply With Quote
Old 01-26-2007, 06:35 AM   #3
crooper's Avatar
Build a 12v DC converter out of an ATX power supply by splicing the 12v (yellow) and negative (black) leads to a suitable connector on your PC to the M2-ATX. Ground the turn on wire (green) to the ATX PSU case. Now you can power your CarPC inside without modification.
crooper is online now   Reply With Quote
Power supply Problem xGROMx Power Supplies 8 03-16-2007 01:19 PM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 01:18 AM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 12:08 AM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
Opus power supply issue dmazyn Power Supplies 2 10-15-2003 06:32 PM
