The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Newbie
Thread Tools Search this Thread Display Modes
Old 02-07-2007, 07:06 PM   #1
My Photos: (0)
Just a headunit problem
i got my bypass for the BOSE factory system in my 2001 pathfinder.
I wired the harness and just gutted the front panel so it all bare.
i plug the connectors in and start the car and the HU doesnt have power, what is a way to diagnois what is wrong with this setup. when i put all the stock components in it works fine.
Chris
iodine is offline   Reply With Quote
Sponsored Links
Old 02-07-2007, 07:14 PM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Do you get any lights at all from the unit? It would be either your ign hookup (if it does have some lights or something at all when off), or your constant 12v hookup if nothing happens no matter what.
Old 02-07-2007, 07:30 PM   #3
My Photos: (0)
yea nothing happens no matter what .. and the problem with this wiring is from the stock stuff the ign is wired into 3 different connectors.. would not having the other stuff in the dash hooked up cause any problems. like maybe power is relayed through the GPS unit then to the lower head unit?
also .. i used a pinch connector from two ends instead of a twist top, would this have any affect on it if the two wires werent touching in the middle?
Old 02-07-2007, 08:54 PM   #4
My Photos: (0)
fixed it .. bad ground... love it.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
HELP!!!..Problem with my Kenwood KDC-MP5028... :( BIzFlawless Car Audio 8 03-31-2007 10:18 PM
stock headunit + aftermarket amp possible? theheel Car Audio 10 09-11-2006 02:12 AM
Problem with directshow filter and WMP EricE Software & Software Development 0 03-01-2006 10:38 AM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 11:50 AM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 03:51 PM
Sponsored Links
Ad Management by RedTyger
