Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 02-11-2007, 10:24 AM   #1
hermangarza's Avatar
Is this even possible?
I know you can plug a cf card to ide with an adapter, but can you got the other way? this board comes with cf connector build in, but i want to plug in a 44 pin hard drive. any ideas?
thanks
computer controlled switches?
hermangarza is offline   Reply With Quote
Old 03-26-2007, 10:33 PM   #2
any one?
Old 03-26-2007, 10:44 PM   #3
MrJamieR's Avatar
“Do not speak unless you can improve the silence”
Carputer Haiku (thanks Ian Hughes)
Serious error.
All shortcuts have disappeared.
Screen. Mind. Both are blank.
MrJamieR is offline   Reply With Quote
Old 03-26-2007, 10:46 PM   #4
briderx's Avatar
I'd say no.. From a quick check on google, it seems like it'd be only the other way around.. I will have to admit, it seems logical that you'd want to do that.. BUT, I don't think there's enough market for any manufacturer to actually produce such an item.
briderx is offline   Reply With Quote
Old 03-27-2007, 06:27 AM   #5
maybe i have to use a pci adapter
Old 03-27-2007, 10:05 AM   #6
MySQL Error
MatrixPC's Avatar
Your mobo doesn't come with an IDE/SATA connector? If you use it as a 2nd drive, USB is another option.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 03-27-2007, 06:42 PM   #7
nope just a cf slot and the rest usb, pci, vga, serial, even dvi
Old 03-27-2007, 09:43 PM   #8
Raw Wave
TruckinMP3's Avatar
I would suggest PCI card with an IDE controller.
TruckinMP3
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
