Quote: Originally Posted by
PrOjEcT_CiViC
My cpu is: Socket 462 , supporting AMD Athlon, Athlon XP, Duron
FSB 400/333/266/200 MHz
Chipset SiS 741+963L
I would stop right now and read a bit on computers. DO NOT BUY ANYTHING!
Your CPU may be socket a, but it does
NOT "support AMD Athlon, Athlon XP, Duron", it
IS one of those. Not both, or all, but
1 of them! This is pretty important information here.
And the FSB usually is listed as 1 number even though the CPU can support usually what it states and the one standard below it.
For example:
A
Intel Pentium 4 3.06Ghz Socket LGA775 with a 800Mhz FSB can only fit into motherboards that have the Socket LGA775. However, not all sockets that take LGA775 chips, can take pentium 4's. Some only take Celerons. Some only take Pentium D. Some only take Extreme Edition. Some may take a mixture as your
motherboard does which for you is that the
motherboard can accept AMD Athlon's, Athlon XP's, and Duron's. And most people leave the FSB alone unless under/over clocking and the CPU decides what it can run at by default. My hypothetical motherboard for my intel chip probably supports 400Mhz, 533Mhz, 800Mhz, and 1000Mhz FSB. The CPU can only run at 800Mhz, so that is what it uses. If it is hot, it may switch over to 533Mhz but that is it.
Basically we need to know what type of
CPU you have, not motherboard.
Every time you have posted specs, they are motherboard specs. If you still don't get it post a link.
