Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 02-20-2007, 02:47 PM   #1
question regarding the power supply
Hi,
I have a spare PC laying around my house so I thought why not use
that for carputer.
But my biggest concern is the Volts it required to run...
This is the motherboard i have:
AsRock K7s41/K7S41GX
http://www.ocworkbench.com/2004/asro...41/k7s41-1.htm
and this is the power supply:
http://www.xoxide.com/orion-xp400-420w-psu.html
My question is this too much? Will I have to buy an inverter?
Or can I just buy an OPUS 250W Intelligent DC-DC PSU?
Will OPUS 250W Intelligent DC-DC PSU work with my motherboard?
Please let me know
Thank you for any support
Cheers guys
PrOjEcT_CiViC is offline   Reply With Quote
Old 02-20-2007, 04:20 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
http://www.mp3car.com/vbulletin/faq-emporium/68636-faq-will-insert-psu-model-power-supply-work-my-system.html
It's a good starting point for where you're at.
I sugest reading anything and everything in the FAQ Emporium to get an understanding of what all is involved.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 02-21-2007, 02:33 PM   #3
Quote: Originally Posted by DarquePervert View Post
http://www.mp3car.com/vbulletin/showthread.php?t=68636
Hello
Thank you for the link, the information is really good but I cant seem to find my computer in there?
Socket 462 , supporting AMD Athlon, Athlon XP, Duron
FSB 400/333/266/200 MHz
Old 02-21-2007, 03:42 PM   #4
Up at the top there is a link to the same page, but it's just older processors.
My Worklog
Old 02-22-2007, 01:46 PM   #5
ya cant seem to find my processor in there.....
any other advice?
Old 02-22-2007, 02:20 PM   #6
Fusion Brain Creator
2k1Toaster's Avatar
Here you go: http://www.journeysystems.com/power_...calculator.php
And you are aware that the socket 462 is commonly called the Socket A, right?
Old 02-22-2007, 02:54 PM   #7
its not there....
yah i know its also called Socket A....
Old 02-22-2007, 03:17 PM   #8
2k1Toaster's Avatar
You don't need the exact model. And you are looking for your cpu right? Not motherboard...
I found quite a few Classic socket A's on there. I am sure your is on there.
What mystery CPU do you have.
Old 02-22-2007, 03:49 PM   #9
any other advice?
You're really not willing to look for much, are you?
Here's the direct link: http://users.erols.com/chare/elec_pentium.htm
As I said, it's a linkUP AT THE TOP OF THE MAIN PAGE. It's labelled 486, Pentium, Pentium II/III, Athlon.
Hopwever, that link isn't going to help you one iota until you know what CPU you're going to drop into that motherboard. Motherboards aren't the most significant factor in power draw.
My Worklog
Old 02-22-2007, 05:04 PM   #10
no no i looked....that's why i said its not there, I know wat link u r talking abt
Yea i was looking for the CPU and not motherboard....
there are bunch of classic on the list....and they range from 35watts to 60watts....not sure what exactly mine is but even if its 60watts then i would have enough power with the OPUS 250W Intelligent DC-DC PSU...
So i guess that answers it....
My cpu is: Socket 462 , supporting AMD Athlon, Athlon XP, Duron
Chipset SiS 741+963L
Old 02-23-2007, 12:28 PM   #11
2k1Toaster's Avatar
I would stop right now and read a bit on computers. DO NOT BUY ANYTHING!
Your CPU may be socket a, but it does NOT "support AMD Athlon, Athlon XP, Duron", it IS one of those. Not both, or all, but 1 of them! This is pretty important information here.
And the FSB usually is listed as 1 number even though the CPU can support usually what it states and the one standard below it.
For example:
A Intel Pentium 4 3.06Ghz Socket LGA775 with a 800Mhz FSB can only fit into motherboards that have the Socket LGA775. However, not all sockets that take LGA775 chips, can take pentium 4's. Some only take Celerons. Some only take Pentium D. Some only take Extreme Edition. Some may take a mixture as your motherboard does which for you is that the motherboard can accept AMD Athlon's, Athlon XP's, and Duron's. And most people leave the FSB alone unless under/over clocking and the CPU decides what it can run at by default. My hypothetical motherboard for my intel chip probably supports 400Mhz, 533Mhz, 800Mhz, and 1000Mhz FSB. The CPU can only run at 800Mhz, so that is what it uses. If it is hot, it may switch over to 533Mhz but that is it.
Basically we need to know what type of CPU you have, not motherboard.
Every time you have posted specs, they are motherboard specs. If you still don't get it post a link.
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 07:45 AM
Power Supply MrGee Newbie 9 06-21-2006 04:44 PM
power supply noob question Yevmeister Power Supplies 7 12-01-2005 09:07 AM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
Power Supply & TFT LCD question VegaBOND General Hardware Discussion 0 03-23-2000 06:07 PM
